You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Prereq only for removing power button.
Parts
No parts specified.
  1. Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors. Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors.
    • Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors.
  2. Remove the single 1.3 mm Phillips #00 screw securing the power button cable bracket to the rear case.
    • Remove the single 1.3 mm Phillips #00 screw securing the power button cable bracket to the rear case.
  3. Carefully grasp the bracket with a pair of tweezers and remove it from the iPhone.
    • Carefully grasp the bracket with a pair of tweezers and remove it from the iPhone.
  4. Remove the following screws securing the power button cable bracket to the inner edge of the rear case:
    • Remove the following screws securing the power button cable bracket to the inner edge of the rear case:
    • One 2.1 mm Phillips #00 screw
    • One 1.7 mm Phillips #00 screw
  5. Grasp the metal bracket covering the power button switch with a pair of tweezers and remove it from the iPhone.
    • Grasp the metal bracket covering the power button switch with a pair of tweezers and remove it from the iPhone.
  6. Remove the single 2.1 mm Phillips #00 screw securing the power button switch to the rear case.
    • Remove the single 2.1 mm Phillips #00 screw securing the power button switch to the rear case.
  7. Pull the power button switch out of its recess on the rear case with a pair of tweezers.
    • Pull the power button switch out of its recess on the rear case with a pair of tweezers.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 141
