iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Lightning Connector and Headphone Jack Cable: step 1, image 1 of 1
    • The next step requires peeling up the Lightning connector and headphone jack cable that is affixed to the inside of the rear case with mild adhesive. We highly recommend using an iOpener on the lower backside of the rear case to soften the adhesive.
  2. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: step 2, image 1 of 3 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: step 2, image 2 of 3 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: step 2, image 3 of 3
    • Use an opening pick to slowly separate the Lightning connector and headphone jack cable from the rear case.
    • Carefully work the pick down the right side of the Lightning connector and headphone jack cable, making sure to stop right as you hit the bottom.
  3. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: step 3, image 1 of 1
    • Insert the pick underneath the right bottom corner of the Lightning connector and headphone jack cable.
  4. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: step 4, image 1 of 2 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: step 4, image 2 of 2
    • Run the opening pick across the top of Lightning connector and headphone jack cable to loosen the adhesive securing it to the rear case.
  5. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: step 5, image 1 of 1
    • Lift and remove the Lightning connector and headphone jack cable assembly out of the iPhone.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 439
