This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
iPhone 6 Home 键的更换
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6 Home 键的更换, Home键: step 1, image 1 of 1
    • 移除2枚固定home键托架的1.9 mm飞利浦螺丝。
    Again, you need a #000
    Tobias - Reply
    My new part had the left home button bracket screw installed. You need to remove it (and can re-use it) before putting the home button bracket back on. If you are attempting this repair, you probably don’t need this tip. But just in case!
    eschrank - Reply
    Confirming what eschrank said. When re-assembling the home button onto the new front panel assembly remove the pre-installed screw, place the home bracket on the assembly then re-use the pre-installed screw to fasten the home bracket (left side).
    Gregory Hall - Reply
    After I finished reassembling my phone, I had an annoying clicking noise when using the phone. I opened it again and found a lose screw sitting near the jack module! It’s the one you can see in step 21 picture, over the circled one on the right. It shouldn’t be removed (there’s no reason) and I absolutely don’t know how it got lose. I’ve put it back where it belongs and will see how things go. (If I don’t add anything after this comment, that means everything’s back to normal.)
    gourgou - Reply
  2. iPhone 6 Home 键的更换: step 2, image 1 of 2 iPhone 6 Home 键的更换: step 2, image 2 of 2
    • 从前面板移除home键托架。
    It is possible to over-tighten these screws, causing the home button to malfunction.
    doog - Reply
    Helpful - thanks for the heads up! :)
    Will Reid -
    It is also possible for the tiny metal piece (not really a screw) that goes over the center of the home button to come out of the bracket & be lost, which will cause issues for making contact when the button is pressed. Now I can't seem to find any kits with a complete replacement...not sure if this is going to affect my fingerprint id capability because I'm having another issue of my phone being disabled due to the cracked lcd that caused the security code to be input several times which has locked me out completely. I'm still trying to find a way to not lose the pictures and videos that I haven't downloaded to my computer. Anyone have any ideas on either issue? Thanks in advance! ;-)
    Dawn - Reply
    Are the home buttons for a 6 plus and 6s plus interchangeable?
    Sheila Smith - Reply
    HI THERE, I WAS WORKING ON IPHONE 6g. I REPLACE THE HOME BUTTON AND AFTER I FINISH THE PHONE WAS DEAD. I WENT BACK AND REPLACE LCD SHIELD PLATE. AND STILLS THE PROBLEM. WHAT ELSE CAN I DO? ANY ONE DOES HAVE ENCOUNTER THIS ISSUE BEFORE CAN YOU PLEASE HELP ME. rosyavellaneda6@hotmail.com
    Rosie Godinez - Reply
    When going backwards, and reassembling, this is where you change from Phillips #00 driver, back to Phillips #000 driver.
    Robert de Schepper - Reply
  3. iPhone 6 Home 键的更换: step 3, image 1 of 2 iPhone 6 Home 键的更换: step 3, image 2 of 2
    • 使用撬棒将home键排线连接器抬升起来,使之从home键脱落,以此来断开home键连接器的连接。
    During this step, I couldn't separate the two connectors. I accidentally managed to tear the flex cable which passes under the LCD shield/plate and up to the other LCD connectors which attach to the motherboard. Can this cable be replaced to restore Touch ID functionality if everything else is intact?
    I can't see any special chip on that part, just seems like an I/O connector?
    James - Reply
    Yep you can. Touch ID functionality won't be lost.
    Didier Daniel -
    I have managed to separate the connector with quite a lot of patience and perseverance. Although there is no sign of physical damage on either side (button end, button-cable/plate end) the Touch ID functionality was lot. Assuming that the damaged side is that of the button cable/plate, this item is not sold on the EU store.
    Massimo Pinto -
    I have found by gently heating the broken screen side with a heat gun or reworker, it makes removing the home button and the connector so much easier to remove with the tip of the spudger and a press on the home button from the front side
    darren - Reply
    During reassembly the home button did not function. I verified the connectors were seated correctly but no read of touch nor of even pressing to return to home screen. This was resolved by me following the guide 'iPhone 6 Home Button Cable Replacement' to swap out my old, original shield plate with the one on the iFixit unit (effectively replacing the home button cable connector with my original one).
    Now up and running.
    Ryan - Reply
    Disconnecting the connector is tricky. Take your time and don't rush it. The pointed spudger end is a little thick to get under there, so I used a corner of the flat end, very carefully.
    DJ Billings - Reply
  4. iPhone 6 Home 键的更换: step 4, image 1 of 2 iPhone 6 Home 键的更换: step 4, image 2 of 2
    Tool used on this step:
    iOpener
    $19.99
    Buy
    • 轻柔地将位于顶端左侧的home键抬升起来,使之从前面板脱离。
    • 请勿始终向上推home键-您只需让一个角脱落,这样您就能用撬棒方便地翘起它。
    • 这层膜很薄。假如您感觉您马上要将按键撕坏了,请施以微热(使用 iOpener,热枪或吹风机)并再试一次。
    I used a hair dryer on this part. It made removing the home button extremely easy. Just take it slow
    peterhubner - Reply
    I too used a hair dryer and slow pressure as did Peter. I found that the adhesive would slowly release if I just held a little constant pressure with my finger and waited.
    Patrick Langvardt - Reply
    This being my first time I found that this step and the following steps to be the most difficult and time consuming. It required A LOT of patience because the rubber membrane and the adhesive holding the cable really don’t want to release without sufficient heating and I was concerned about overheating the assembly. Using a hair dryer on the slowest setting finally worked.
    fiftysomething - Reply
    Cette étape demande vraiment de la patience. J’ai juste attendu en exerçant une faible pression et au bout d’un moment ça s’est décollé.
    Il ne faut pas mettre trop de pression et avoir un bon éclairage pour voir l’état de la membrane au fur et à mesure.
    Chloé Bossuette - Reply
    I made the mistake of not using a hair dryer, I slowly pried the part up but in doing so the adhesive strip was no longer reusable. With no glue in the house I used a piece of the old battery adhesive strip as I changed the battery first. I cut the strip into very fine pieces, placed them under the steel cover plate in order to pinch the rubber gasket. Changing the battery and glass plate was easy but the tiny adhesive strip held me up for over an hour. Without the adhesive strip on the rubber gasket the push button will not work. I need to find out what glue is suitable for this application.
    Joseph O'Brien - Reply
    Joseph, I use this tape. The version I use is made by 3M. I find it’s a good compromise—strong enough to hold well, but loosens with heat and isn’t so strong that you rip the membrane (or whatever delicate phone part you’re working with) should you need to remove it. I’m not endorsing Amazon; you can get this stuff on eBay, from most phone repairers, etc. It comes in 1mm, 2mm, 3mm, 4mm, 6mm, 8mm, 1cm—just about any width you’d want, and is fairly easy to work with.
    ​1mm x55M Clear Double Sided Strong Adhesive Tape For Phone LCD Screen Repairby GENNEL DirectLearn more: https://smile.amazon.com/dp/B019OSYR1Q/r...
    Bonnie Baxter -
    Hair dryer worked the best!!! just be patient, takes like 5 min… use the tip of the spudger and skratch a little bit on the corner.
    Renata Torres Balderas - Reply
    I used the heat from my halogen bulb desk lamp and it did the trick right-away
    Rich Tea - Reply
  5. iPhone 6 Home 键的更换: step 5, image 1 of 2 iPhone 6 Home 键的更换: step 5, image 2 of 2
    • 使用撬棒轻轻翘起HOME键
    Don't get in a hurry with the ribbon. Heat and a gradual constant pressure did the trick.
  6. iPhone 6 Home 键的更换: step 6, image 1 of 2 iPhone 6 Home 键的更换: step 6, image 2 of 2
    iOpener
    $12.99
    Buy
    • 使用撬棒较细一头轻轻将HOME键撬起,注意屏幕与HOME键之间的粘合剂。
    • 如果您无法轻而易举地分开线缆,请使用诸如iOpener或者吹风机来加热粘合剂,使之软化,然后再试一次。当心,不要损坏线缆。
    This step really requires patience- I had to heat the area several times and “spudge” from both sides before the cable successfully loosened. Even under a strong magnifying glass, it will look like the middle section with the tiny circuit board is fused into the plastic, but it’s just strong adhesive, which eventually softens.
    Dan - Reply
    Dan, is there any source that indicates the maximum temperatures to which you can heat the different areas of an iPhone when necessary to loosen adhesives? Or time/power parameters for specific heat guns?
    Tomas Delaveau -
    This part almost killed me. In the video, they’ve already loosened the adhesive so she pops it right off. The hair dryer should be set to hot and low blowing. It’ll take a few minutes & a few tries) to loosen the adhesive. I aimed at all sides of the cable (ie at both ends where the cable meets the case & straight on at the circuit board). To finally get it off, I mixed up using a spudger to play with it and a very fine tweezer to finally get a good enough grip to pull the button assembly off.
    dhcohen67 - Reply
    I believe is better to heat the panel from te outside because the heat transfer would flow in a way that the adhesive will be at a higher temperature than the cable
    Tomas Delaveau - Reply
    would love to know temperature allowances/tolerances here. how hot is too hot? What temp does the adhesive relax at?
    flow in - Reply
    How do you remove the metal backplate shield's connector [which interfaces with the home button] glued to the plastic coating on the screen?
    Valtér Hégér - Reply
    The rubber gasket adhesion was minimal when I removed the button. I cleaned and replaced it, but it had no adhesion. I’m not sure if that’s how it is meant to be.
    Teri Wright - Reply
  7. iPhone 6 Home 键的更换: step 7, image 1 of 1
    • 分离粘合剂和HOME键之后,便可分离HOME键。
    • 如果是更换碎屏,HOME键上可能会有玻璃残渣,更换新屏幕前,请先清理干净。
    One thing to note for re-assembly. You have to make sure the home button is firmly in place. Otherwise, a lack of adhesive will cause the home button to sink into the iPhone after it's fully assembled when you try to press it.
    rskrobe - Reply
    Are you sure that you screwed the metal plate back in far enough? I don't have any issues and can't believe that Apple would rely on adhesive to hold the home button from sinking into the phone. Especially as it's the most pressed button on the iPhone.
    Thomas Hallett -
    Yeah, you have to buy new gaskets if you want you're home button to stick to the digitizer frame when pressing. Don't believe me? Just see what happens when you press the button without new adhesive :) And heck I bought 50 gaskets for only $5 from China.
    Didier Daniel -
    On the old screen,there were 2 little rubber covers that fit on the screw mounts (that hold the pentalobe screws from Step 1) that I transferred to the new part.
    jefowler4th - Reply
    I would add a few extra steps to this (i had to disassemble and reassemble 5 times).
    First, adding the Ifixit forward facing camera replacement, and I would add the steps 12-16 fromt his guide on how to take off the heat shield (also has the fingerprint cable).
    http://www.instructables.com/id/iPhone-6...
    Thanks again.
    Roland Bodenheim - Reply
    after placing the home button again, it dose not read my finger prints anymore! any idea? Thanks.
    Khal Sh - Reply
    For all the iphone 6 series once the original home button ribbon is torn or damaged the touch ID will never work again. Even if you replace the home button/ribbon. This is a security feature implemented by Apple. Once the original cable for the phone has been damaged or replaced, the touch ID functionality is gone forever.
    Tony - Reply
    Dear After replacing the cracked screen successfully I turn it ON and the apple logo keeps coming and going as if it is like rebooting continuously any IDEA?
    Cesar
    cesarclaudio - Reply
    I'm having the same issue. Did you ever get a response to your question?
    Kevin Rivera -
    This is missing a step ... most replacement screen assemblies also are missing a small metal plate that sits under the place where the home button connector and flex cable connector rest. Apparently without this metal the touch ID cannot be enabled. That said .. I'll not know on this phone since after following these directions and finding out I needed to pull apart the home button a second time to place this metal plate there the connector would not separate and it ripped the flex cable from the connectors completely. Now it's time to get a new home button and touch ID will never work on this phone again :(
    cueball - Reply
    My new screen comes with the home button cable, if I just swap the original home button to the new front panal will I retain touch ID? Or do I need the original cable too?
    nathanation - Reply
    if you want touch id to work the cable going from the home button to the logic board must be changed also
    https://www.youtube.com/watch?v=8IEWAQiu...
    Eric Ocegueda - Reply
    That isn't what my home button looks like? It didn't have the little sensor on it, just the button and it still worked but now doesn't... Anyone know why?
    Emie Jayne - Reply
    despues de serguir la guia fue exitosa solo que tengo un problema no reconoce la huella me dice error al configurar el touch id alguna solucion???
    CHARLES - Reply
    When I was transferring my home button, it was covered in tiny shards of glass as the instructions warned. I found I was able to remove many of the shards and to clean up the button by wrapping a piece of scotch tape around my finger sticky side out and then gently dabbing at the shards.
    davechar - Reply
    https://support.apple.com/en-us/HT205628
    Does this iOS update mean that it is no longer necessary to replace the cable going from the home button to the logic board as well?
    Peter Barnett - Reply
    The only “problem” that I had, was that the home button connector on the iFixit replacement screen assembly was “floating” and made it very difficult initially to connect the home button cable connector. i eventually glued it down to the screen assembly with some Pritt glue and the connection was easy.
    Thanks for everything.
    I just bout the Fix Kit from iFixit, I did every step 9-11 times, carefully. Everytime I try to turn on the phone when everything is assembled it won’t turn on. The screen remains black eventhough the phone is on and itunes can detect it. if I put the broken screen back I get the creen powered on.
    Is my recently aquired screen replacement broken? Thanks
    Will - Reply
    Solved. The new screen was not working. I now hace some stains on the upper part of the screen.
    Will -
    I had set my phone up as an erased “new iPhone” prior to the repair. After completing this repair my Touch ID appeared to be working normally and I added 4 fingerprint profiles. After a few hours Touch ID failed and the fingerprint profiles disappeared. Attempting to add them again would not work. After performing a “Hard Reset” the previously entered fingerprints returned and functionallity has been completely normal for a couple of days now. I will repost if another failure occurs.
    Steve Mattson - Reply
    When moving original home button to new screen, a tiny dab of adhesive from a Pritt Stick helped hold the cable onto the front panel. Great guide, all worked well, and touch ID working, thanks.
    Mike Cowley - Reply
    My home button was extremely loose when installed in this fashion. To help remedy it, I installed the gasket sandwiched between the button and glass instead of on the rear face of the button. Not perfect, but a much better feel. Prior to that, the button actually stuck out further than the glass.
    kwschnautz - Reply
    So my repair went off without a hitch, but my home button when I click it kinda has a hollow-like sound/feel to it, is it something I did wrong?
    Peter Keller - Reply
    You didn’t show removing the top part, camera, etc.
    William Wong - Reply
    I did not have a hair dryer on hand so I used the metal tweezers very carefully to lift the gasket and connector. Reinstalling it was tricky but I found sticking the connector back onto the two tiny pins made it a lot easier to guide the button into place.
    Nicholas Hooker - Reply
    I replaced my battery and my screen on an Iphone 6 for under $100. My phone looks and works like new. Great online tutorial, just go slow and be careful. I dropped a screw in the carpet and thought I was screwed. By some miracle I spotted it, the size of a pin head. Use a magnetic try if possible and do the work over a tile floor. I’m 66 years old, you can do it!
    Thomas m Burke Jr - Reply
    On the screen I purchased from iFixit, the the connector’s cable was .5mm too long so that it wouldn’t fit on the two tiny pins. But I have put it all back together and it works great.
    Greg Scott - Reply
    My IFixIt kit worked well. Gifted to me by a friend along with the project tray. The tiny screws are hard to handle, but the guide got me through. The phone charged and turned on like the screen was never dead. Only thing is the home button doesn’t respond to fingerprints. No big deal for me. Thanks for the great products and instructions.
    Lo'real Barrow - Reply
    The new screen from your Store came with not one—but 2—screws, and they were loose in the package. I used one where the photo shows a screw in the top right of the button bracket, but I didn’t compare the new screen to the old one further to figure out where the second one *might* have been needed. So far, phone is restored, and I’ll only go back to place the screw if the phone ever acts up (or someone here comes on to warn me of certain doom). Thanks once again iFixit for the part, the tools, the video, the step-by-steps, and this community. Could not have done this without any of you!
    Sue Livingston - Reply
    There seems to be a step missing? The little connector that the home button is plugged into seems to be glued pretty hard onto the frame. How is that supposed to be loosened?
    mortenskogly - Reply
    It's not glued in, it's "plugged into" the logic board. You just need to unplug it. Take your time and gently pry it up from one corner. Eventually it will pop off.
    DJ Billings -
要重新装配您的设备,请按逆序操作。
9 other people completed this guide.
Special thanks to these translators:
en zh
81%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Sam Goldheart
465,659 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,757 Guides authored
One Comment
Home button robin cable malfunction after replaced.
Replaced broken Home button robin cable, now the phone will not turn on unless I unplug the home button cable from the mother board! I've thought of placing the phone in recovery mode and placing the phone in factory setting then trying to reconnect the cable, BUT to do that the home button has to be WORKINGand it's NOT working. Also the phone as the current iOS on it... Any ideas other than buying a new home button cable and trying the replacement again?
Hector - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 6,037
