iPhone 5 Screen Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. iPhone 5 Screen Replacement, iPhone Screen: step 1, image 1 of 1
    • Before we start, please make sure your iPhone has been turned off.
    • Now you can unscrew the two star-shaped screws next to the charging interface
  2. iPhone 5 Screen Replacement: step 2, image 1 of 1
    • Put a small suction cup above the home button to hold the screen glass.
    • Make sure your suction cup sucks tight enough!
  3. iPhone 5 Screen Replacement: step 3, image 1 of 1
    • Pinch the suction cup in one hand and carefully lift the screen assembly.
    • Through the attractive body of the iPhone 5 we can guess that the assembly of the screen and the fuselage fit more compact, so you need a slightly larger force for the screen from the fuselage.
    • As there are some clips that hold the screen, you must use the plastic ignition tool shown in the illustration.
  4. iPhone 5 Screen Replacement: step 4, image 1 of 1
    • Slowly lift the buckle along the fuselage with a plastic ignition tool.
  5. iPhone 5 Screen Replacement: step 5, image 1 of 2 iPhone 5 Screen Replacement: step 5, image 2 of 2
    • Once buckle is open, you can move screen by pulling the suction cup.
    • Be careful, there are cables behind the screen, so do not remove whole screen at this moment.
    • Hold the camera side and then pull the screen to make a V shape, but still do not disconnect with the mainboard.
    • You may now see components inside iPhone 5.
  6. iPhone 5 Screen Replacement: step 6, image 1 of 1
    • Unscrew the three screws as shown.
  7. iPhone 5 Screen Replacement: step 7, image 1 of 2 iPhone 5 Screen Replacement: step 7, image 2 of 2
    • Remove the small baffle.
  8. iPhone 5 Screen Replacement: step 8, image 1 of 3 iPhone 5 Screen Replacement: step 8, image 2 of 3 iPhone 5 Screen Replacement: step 8, image 3 of 3
    • Use a plastic tool to gently disconnect three interfaces as shown, it is similar as cloth clips, no worry to welding.
    • The screen is connected to the mainboard through these three interfaces: front camera cable, touch screen cable, and the LCD screen cable.
  9. iPhone 5 Screen Replacement: step 9, image 1 of 1
    • After disconnecting these three interfaces, now you can remove the screen.
  10. iPhone 5 Screen Replacement: step 10, image 1 of 1
    • Remove the two screws as shown.
  11. iPhone 5 Screen Replacement: step 11, image 1 of 2 iPhone 5 Screen Replacement: step 11, image 2 of 2
    • Remove this small part above the speaker.
  12. iPhone 5 Screen Replacement: step 12, image 1 of 1
    • Now you can remove the speaker.
  13. iPhone 5 Screen Replacement: step 13, image 1 of 2 iPhone 5 Screen Replacement: step 13, image 2 of 2
    • In the position shown in the picture, there is a small cable connector, which can be gently removed with a plastic tool.
  14. iPhone 5 Screen Replacement: step 14, image 1 of 1
    • After you open the interface, you can remove the front camera.
  15. iPhone 5 Screen Replacement: step 15, image 1 of 1
    • Unscrew the two screws as shown.
  16. iPhone 5 Screen Replacement: step 16, image 1 of 2 iPhone 5 Screen Replacement: step 16, image 2 of 2
    • Before you take off the flap of Home button, you must unplug connected cables.
    • Note: the cable is glued instead of buckle type conunction, so you must be more careful.
  17. iPhone 5 Screen Replacement: step 17, image 1 of 1
    • Remove the Home button shield and the cable.
  18. iPhone 5 Screen Replacement: step 18, image 1 of 2 iPhone 5 Screen Replacement: step 18, image 2 of 2
    • Pry the Home button out with the plastic prying tool.
  19. iPhone 5 Screen Replacement: step 19, image 1 of 1
    • Remove the Home button.
  20. iPhone 5 Screen Replacement: step 20, image 1 of 2 iPhone 5 Screen Replacement: step 20, image 2 of 2
    • Remove the screws as shown in the figure, each side has two.
  21. iPhone 5 Screen Replacement: step 21, image 1 of 1
  22. iPhone 5 Screen Replacement: step 22, image 1 of 2 iPhone 5 Screen Replacement: step 22, image 2 of 2
    • Remove the LCD screen shield.
  23. iPhone 5 Screen Replacement: step 23, image 1 of 1
    • Finally you have the iPhone 5 screen with integrated components.
    • Replace the screen with a new one, and reverse the operation set forth before to assemble it back to your iPhone.
    • If your friend or you have a broken iPhone 5 screen, what are you waiting for? It is your show time! If you don't have a broken one, try to make one.
    • Have a good day, and Good Luck!
In order to reassemble your device, follow these instructions in reverse order.
14 other people completed this guide.
Special thanks to these translators:
zh en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
ixiuer
3,807 Reputation
1 Guide authored
Master Techs Member of Master Techs
Community
322 Members
2,528 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 18,605
