Introduction
遵循本指南对Home键排线进行替换。排线包含了开关结构,但不包含键帽。
无论你使用什么工具,你需要确定你把整个显示屏拉起来了。
如果玻璃开始从塑料分离,如图一所示,在塑料框架和金属手机之间滑动塑料小撬棒,以撬出后机壳的金属夹。
将蓝色手柄拉向铰链以解锁反向钳的手臂。
将反向钳手臂滑过 iPhone 的左边缘或右边缘。
将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
向下推吸盘以将吸力施加到所需区域。
请务必在维修继续前断开电池,如果不这样做的话,有时会导致手机运行太热和/或与触摸敏感问题。
当前面板组件底部和侧面夹扣被撬起后,拉动组件的底部使之远离后壳。
缓慢提升前面板组件跟后壳体成约90度。
卸下两颗1.3mm飞利浦#000螺丝,此螺丝用于将Home键支架固定于显示面板。
注意:当重新安装两颗1.3mm飞利浦#000螺丝的时候,注意不要上得过紧,避免螺丝将显示面板的另一面顶破。
若要重新组装你的设备,请按照以下步骤逆向操作。
161 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
3 Comments
You had mentioned the phone running hot if the battery wasn't disconnected in the correct sequence, how is this resolved? Also, the phone after lcd assembly replacement is unresponsive, I have gotten a dinging sound that repeats but nothing on the screen...iTunes recognizes the phone but I get nothing on the screen, I've tried reassembling several times with no luck, this is not my phone, I've done many repairs on iphones in the past
and never had this problem...please help, it's an iphone 5s
what kind of adhesive is used on the home button cable - the one with two metallic spherical plates that face the inside of the phone?
one of the screws on the home button is unscrew-able and i had to get my dad to do it and he could not even do it, im replacing the one on my old iphone to my new replacement screen and know one had ever touched it before, any ideas on what i can do?
