Introduction
Internal prerequisite.
Use the edge of a plastic opening tool to dislodge the headphone jack off from its recess in the outer case.
Use the edge of a plastic opening tool to peel the top microphone away from the outer case.
Pull the body of the headphone jack away from the top edge of the iPhone.
Remove the four 1.5 mm Phillips screws securing the volume button and silent switch brackets to the outer case.
Carefully peel the headphone jack/volume button cables off the adhesive securing them to the rear case.
Remove the headphone jack cable assembly from the iPhone.
