iPhone 5 at&t Dock Connector Replacement
  1. iPhone 5 at&t Dock Connector Replacement, Rear Panel: step 1, image 1 of 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
  2. iPhone 5 at&t Dock Connector Replacement: step 2, image 1 of 2 iPhone 5 at&t Dock Connector Replacement: step 2, image 2 of 2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 5 at&t Dock Connector Replacement: step 3, image 1 of 1
    • Pinch the rear panel with your fingers, and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
  4. iPhone 5 at&t Dock Connector Replacement, Battery: step 4, image 1 of 1
    • Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board (if present).
  5. iPhone 5 at&t Dock Connector Replacement: step 5, image 1 of 1
    • Use the edge of a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break it entirely.
    • Remove the metal clip covering the antenna connector.
  6. iPhone 5 at&t Dock Connector Replacement: step 6, image 1 of 2 iPhone 5 at&t Dock Connector Replacement: step 6, image 2 of 2
    • Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
    • If the tab breaks before the battery is freed, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery. Wait about one minute for the alcohol solution to weaken the adhesive. Carefully slide a spudger under the battery tab to release the adhesive.
    • Prying in other places may cause damage. Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  7. iPhone 5 at&t Dock Connector Replacement, Speaker Enclosure Assembly: step 7, image 1 of 2 iPhone 5 at&t Dock Connector Replacement, Speaker Enclosure Assembly: step 7, image 2 of 2
    • Remove the two 1.8 mm Phillips screws securing the dock connector cable cover to the logic board.
    • Remove the metal dock connector cable cover.
  8. iPhone 5 at&t Dock Connector Replacement: step 8, image 1 of 1
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  9. iPhone 5 at&t Dock Connector Replacement: step 9, image 1 of 1
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  10. iPhone 5 at&t Dock Connector Replacement: step 10, image 1 of 2 iPhone 5 at&t Dock Connector Replacement: step 10, image 2 of 2
    • Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator.
    • Remove the pressure contact.
    • When reinstalling the pressure contact, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
  11. iPhone 5 at&t Dock Connector Replacement: step 11, image 1 of 2 iPhone 5 at&t Dock Connector Replacement: step 11, image 2 of 2
    • Use the edge of a plastic opening tool to pry the Wi-Fi antenna cable up from its socket on the logic board.
    • De-route the Wi-Fi antenna cable out from under the metal fingers attached to the logic board.
  12. iPhone 5 at&t Dock Connector Replacement: step 12, image 1 of 1
    • Remove the two 2.4 mm Phillips screws securing the speaker enclosure assembly to the outer case.
  13. iPhone 5 at&t Dock Connector Replacement: step 13, image 1 of 1
    • Remove the small black spacer that was under the Phillips screw near the vibrator.
  14. iPhone 5 at&t Dock Connector Replacement: step 14, image 1 of 3 iPhone 5 at&t Dock Connector Replacement: step 14, image 2 of 3 iPhone 5 at&t Dock Connector Replacement: step 14, image 3 of 3
    • Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna.
    • Remove the speaker enclosure assembly.
    • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
    • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
  15. iPhone 5 at&t Dock Connector Replacement, Dock Connector: step 15, image 1 of 1
    • If present, remove the small strip of tape covering one of the dock connector screws.
  16. iPhone 5 at&t Dock Connector Replacement: step 16, image 1 of 2 iPhone 5 at&t Dock Connector Replacement: step 16, image 2 of 2
    • Use a plastic opening tool to flip up the retaining flap on the home button ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  17. iPhone 5 at&t Dock Connector Replacement: step 17, image 1 of 1
    • Use a pair of tweezers to pull the home button ribbon cable out of its socket.
  18. iPhone 5 at&t Dock Connector Replacement: step 18, image 1 of 1
    • Carefully pull, but do not remove, the rubber microphone holder out of its tube in the bottom edge of the iPhone.
  19. iPhone 5 at&t Dock Connector Replacement: step 19, image 1 of 1
    • Remove the two 1.3 mm Phillips screws securing the dock connector to the case of the iPhone.
  20. iPhone 5 at&t Dock Connector Replacement: step 20, image 1 of 1
    • Use a pair of tweezers to remove the small rubber spacer beneath the speaker enclosure mounting ear near the vibrator.
  21. iPhone 5 at&t Dock Connector Replacement: step 21, image 1 of 1
    • Remove the tiny rubber spacer near the dock connector.
  22. iPhone 5 at&t Dock Connector Replacement: step 22, image 1 of 2 iPhone 5 at&t Dock Connector Replacement: step 22, image 2 of 2
    • Use the edge of a plastic opening tool to peel the dock connector and its cable off the black plastic case of the iPhone.
    • If you are replacing the dock connector with a new part, make sure to transfer the rubber casing around the microphone. You can do this using a spudger.
  23. iPhone 5 at&t Dock Connector Replacement: step 23, image 1 of 2 iPhone 5 at&t Dock Connector Replacement: step 23, image 2 of 2
    • Pry the dock connector away from its opening at the bottom of the iPhone.
    • Remove the dock connector.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 37,405
