Introduction
Luckily, replacing the battery on the iPhone 4 requires minimal disassembly. If your battery is swollen, take appropriate precautions.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Power off your iPhone before beginning disassembly.
Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Push the rear panel toward the top edge of the iPhone.
Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board (if present).
you do not need to take the battery out as chuck said so you dont run the risk of braking the battery connector socket from the logic board
Won't you need the battery removed to access the large-headed screws on the side which hold the front display?
Unfortunately the battery screw was already stripped probably from original assembly. We used a pair of nail clippers as pliers to grab a hold of the screw by the edges to turn it. If it hadn't have been for the stripped screw it would have taken us about 10 minutes, as it was it took us 30-40 minutes if you count searching for solutions for removing the stripped screw.
Use the edge of a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the metal clip covering the antenna connector.
Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
Remove the battery.
Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
Note that the pull tab is not actually attached to the battery. It is attached to the iPhone chassis, and is only used to separate the battery from the adhesive. (Don't expect it to come out with the battery!)
Also, the adhesive is VERY strong. I had to use my plastic opening tool to assist in prying the battery loose. This is probably the most nerve-wracking part of the job.
It is much easier to slightly WARM the battery with a HAIRDRYER not a HEAT GUN to soften the adhesive. DO NOT GET BATTERY HOT AND DO NOT USE HEAT GUN
Joe -
I just did this today. Everything was as scripted. Mine had lots of adhesive and had to use plastic spudger to go around battery to loosen up. Do not use plastic tab until you can see under battery a little bit. Great instructions. Took less than 10 minutes.
The adhesive is very strong and I was initially worried about damaging the phone by prying so much. There are a couple of places below the volume switch where you can pry between the metal of the case and the battery. If you lift the battery just a little, wiggle the pry bar further in and then start moving down the case. Don't worry about bending the battery, its dead anyway.
Do not pry on the left side (circuit board side) and do not use the pull tab until the adhesive is broken loose.
I tried this at first with a plastic pry tool, and the adhesive was so strong that I broke the tool. I then used a large screwdriver and applied pressure very slowly along various places on the outer side of the battery. That eventually did the trick.
439 other people completed this guide.
12 Comments
I actually had the plastic tab break off when I was trying to remove the battery. Any advice?
Na Aula,diz pra vc coloca álcool isopropílico 90% pra enfraquecer a cola do.
The plastic opening tools were amazing flimsy- the tips broke off both of them while trying to get the battery out.
The adhesive attaching the battery was very strong and the pull tab actually ripped, though it did not come off.
When I replace my battery for a new one it says accesory not permited or something like that, and I tried with every single battery I found (iphone 4 GSM, Iphone 4s..) is there something I could do? is the battery of iphone 4 CDMA Verizon different from others?
I have a Verizon iPhone 4. Got it the first day Verizon started selling them over 2 years ago. Followed the guide. Completed the task in 10 mins. The battery adhesive must have weakened some. Did not need to use pull tab at all. Just the pry tool along the outer side of battery as mentioned by other users. Thanks ifixit!! Saved me a contract slot. With a family of 4, that is a big savings.
Has anyone had trouble with the battery draining really really <i.e. 10% in 15 min> fast after removing the battery?
Directions posted above worked perfectly for me. The battery was glued in pretty tight (phone is a couple years old) but was able to pry it out with the tool, working my way around the edges. Total time about 10 minutes.
Thanks so much!
This was very easy. The plastic tab did breeak off, but it seemed brittle to begin with. I had to use the pry took to separate the bttery from the case, but it came out easily. Reassembly was a bit tricky getting the battery connection lined back into the logic board. Once it was properly aligned it went fast after that. I had ordered the "Liberation Kit" along with the battery and there was no extra cost for the "Kit". This was a great deal. THANK YOU iFixit for helping us peons to fix it ourselves!
The CDMA iPhone 4 battery replacement is quite easy especially if you get the ifixit tool kit with the battery. The tab did break quite easily a hair dryer (not a heat gun) on low helped soften the glue (warm up the battery to soften ) DO NOT BAKE! Took all of 10 Minutes.
Simple and straight forward replacement of battery. Right tools and step by step instructions took less than 10 minutes. IPhone 4 is up and running. $25 total with shipping versus $600 for a new phone and another BS contract with a wireless company where they screw you out of services and make you pay for things when you weren't paying for them before. Thank you Ifixit!
Read comments above before starting. Had no issues at all. Did not strip screw heads and battery was removed easily. Tools worked well and didn't break. Did not have to do a hard restart as well. Now, just need to drain the new battery to 10% so I can fully charge. Learn from others issues and avoid problems by reading the above.
today is 10/01/2020 and just had to replace a battery in this for a customer . Along with a screen and then a comport flex. I guess some folks still hold on to things they love .
Pra descarregar a bateria, antes de fazer o serviço, isso serve pra qualquer celular?
Gilmar Dutra - Reply
