Introduction
No audio? Replace the headphone jack!
Insert a SIM card eject tool or paper clip into the hole next to the headphone jack.
Press down on the paper clip until the SIM card tray pops out.
Insert a metal spudger into the slot between the dock connector and the antenna cover. Gently pry up near the two tabs to create a small gap between the antenna cover and the silver front bezel.
Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
Repeat the same procedure on the other side of the dock connector.
Grasp the antenna cover on either side and slide it up and away from the iPhone. This requires some force. If it does not come free, ensure that the antenna cover is lifted up enough to free the catches.
The small square hole is the location to insert the dental pick in the next step.
Insert the pointed end of a heavy-duty spudger into the space between the gray metal bar and the rear panel. Pry the panel up enough until you can get the tip of the iPod opening tool into the seam between the front bezel and rear panel.
Start removing the rear panel on the side with the buttons.
Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
Pry up the rear panel by pulling the dental pick counterclockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
Repeat the same procedure on the other side of the iPhone. Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
The rear panel is still attached to the iPhone by the headphone jack cable, so don't entirely remove the rear panel from the iPhone just yet.
Remove the following 3 screws:
Two Phillips #00 screws securing the vibrator to the rear panel.
One larger head and longer Phillips #00 screw securing the headphone jack to the rear panel.
Grasp the metal screw plate attached to the on/off switch and lift slightly up and away from the rear panel. The button should come with the cable.
Gently peel up the on/off switch ribbon cable. Be sure to pull near where the ribbon cable is glued to the rear panel.
The headphone jack is slightly recessed into the rear panel. First slide the headphone jack away from its housing and then lift it up slightly (only 1/4 inch or 1/2 centimeter) so that it is no longer in the rear panel.
Grasp the headphone jack at the tip and gently lift up, pulling the vibrator out of the rear panel.
Remove the two Phillips #00 screws securing the silent/ring switch to the rear panel.
Pry off the metal backing with the screw holes and save for securing the replacement switch.
