iPhone 16 Pro 5G mmWave Antenna Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iPhone 16 Pro 5G mmWave Antenna Removal, Prepare the phone for disassembly: step 1, image 1 of 2 iPhone 16 Pro 5G mmWave Antenna Removal, Prepare the phone for disassembly: step 1, image 2 of 2
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
    Ask FixBot
  2. iPhone 16 Pro 5G mmWave Antenna Removal, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Pro 5G mmWave Antenna Removal, Tape over any cracks: step 2, image 2 of 2
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Ask FixBot
  3. iPhone 16 Pro 5G mmWave Antenna Removal, Mark your opening picks: step 3, image 1 of 3 iPhone 16 Pro 5G mmWave Antenna Removal, Mark your opening picks: step 3, image 2 of 3 iPhone 16 Pro 5G mmWave Antenna Removal, Mark your opening picks: step 3, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  4. iPhone 16 Pro 5G mmWave Antenna Removal, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 16 Pro 5G mmWave Antenna Removal, Remove the pentalobe screws: step 4, image 2 of 2
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
    Ask FixBot
  5. iPhone 16 Pro 5G mmWave Antenna Removal, Disconnect the earpiece speaker: step 5, image 1 of 3 iPhone 16 Pro 5G mmWave Antenna Removal, Disconnect the earpiece speaker: step 5, image 2 of 3 iPhone 16 Pro 5G mmWave Antenna Removal, Disconnect the earpiece speaker: step 5, image 3 of 3
    • The 5G mmWave antenna is only in United States and Puerto Rico iPhone 16 Pros (model A3083). For all other models, skip the next four steps.
    • Use the point of a spudger to pry up and disconnect the earpiece speaker and 5G mmWave antenna press connectors, located on the top right corner of the logic board.
    Ask FixBot
  6. iPhone 16 Pro 5G mmWave Antenna Removal, Remove the earpiece speaker: step 6, image 1 of 1
    • Use a Phillips screwdriver to remove the six screws securing the earpiece speaker:
    • Three 1.2 mm‑long screws
    • Two 1.8 mm‑long screws
    • One 1.7 mm‑long screw
    Ask FixBot
  7. iPhone 16 Pro 5G mmWave Antenna Removal: step 7, image 1 of 3 iPhone 16 Pro 5G mmWave Antenna Removal: step 7, image 2 of 3 iPhone 16 Pro 5G mmWave Antenna Removal: step 7, image 3 of 3
    • Insert the point of a spudger in the bottom-right corner of the earpiece speaker and pry it up to remove it.
    • You may feel some resistance near the top edge, where the speaker gasket seals against the frame. Pull the speaker out gently to release the seal.
    Ask FixBot
  8. iPhone 16 Pro 5G mmWave Antenna Removal, Remove the stretch release adhesive: step 8, image 1 of 3 iPhone 16 Pro 5G mmWave Antenna Removal, Remove the stretch release adhesive: step 8, image 2 of 3 iPhone 16 Pro 5G mmWave Antenna Removal, Remove the stretch release adhesive: step 8, image 3 of 3
    • Use your tweezers to grab the stretch release adhesive pull tab, located on the edge of the 5G mmWave antenna.
    • Use your tweezers to pull the stretch release adhesive strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the antenna.
    • For additional grip, you can twist the adhesive around the tip of the tweezers while you pull.
    • If the adhesive strip breaks off, try to retrieve it with your tweezers and continue pulling.
    Ask FixBot
  9. iPhone 16 Pro 5G mmWave Antenna Removal, Remove the antenna: step 9, image 1 of 2 iPhone 16 Pro 5G mmWave Antenna Removal, Remove the antenna: step 9, image 2 of 2
    • Lift the 5G mmWave antenna off the earpiece speaker and remove it.
    Ask FixBot
To reassemble your iPhone, follow these instructions in reverse order.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers Community for help.
Nick Schultz
58,401 Reputation
316 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,236 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 180
