iPad Pro 9.7" Battery Replacement
  1. iPad Pro 9.7" Battery Replacement, SIM Card Tray: step 1, image 1 of 3 iPad Pro 9.7" Battery Replacement, SIM Card Tray: step 1, image 2 of 3 iPad Pro 9.7" Battery Replacement, SIM Card Tray: step 1, image 3 of 3
    • Insert a SIM card eject tool, bit, or a paperclip into the small hole in the SIM card tray, located near the bottom edge of the iPad.
    • Press firmly to eject the tray.
    • Remove the SIM tray.
    My iPad Pro 9.7 wifi only has no pinhole for sim card
    Michelle - Reply
    You’re right! The Wi-Fi only model does not have a pinhole. Skip this step for your iPad.
    Arthur Shi -
  2. iPad Pro 9.7" Battery Replacement, iPad Pro 9.7" Opening Procedure: step 2, image 1 of 3 iPad Pro 9.7" Battery Replacement, iPad Pro 9.7" Opening Procedure: step 2, image 2 of 3 iPad Pro 9.7" Battery Replacement, iPad Pro 9.7" Opening Procedure: step 2, image 3 of 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    Covering the screen with tape proved an essential safety step with the ipad display/lcd I just replaced. The screen was so badly broken that a part of it was almost powder, but the combination of the tape and sticky adhesive residue kept most of that together, and cleanup was pretty easy as a result. One caveat, though, is that the tape will probably make the suction cup useless for pulling up on the display. It did for me, anyway.
    John Lasseter - Reply
  3. iPad Pro 9.7" Battery Replacement: step 3, image 1 of 1
    • The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
    • Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
    • Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
    I see a lot of videos that show using a heat gun on low to soften the adhesive. I know there is inherent risk with this since you could start delaminating things, but is it something that could be considered (at your own risk)? Or is it something that could have more risks than I am realizing?
    joshcorey - Reply
    Yes, you can definitely use a hair dryer, heat gun, or a heating pad. If you're using a heat gun, be careful not to overheat the display. The surface should feel slightly too hot to the touch.
    Arthur Shi -
  4. iPad Pro 9.7" Battery Replacement: step 4, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 4, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 4, image 3 of 3
    • While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Home Button
    • Front Facing Camera
    • Main Camera
    Verwirrend: Es sollte heissen, dass man an den beschriebenen Stellen eben NICHT hebeln sollte.
    Felix - Reply
    Danke! Ich habe den Teil mit dem NICHT hebeln nochmal hervorgehoben.
    Fabian Neidhardt -
    The screen cable is on the right side at the bottom. Be super careful not to slice too deeply there
    Gerald - Reply
  5. iPad Pro 9.7" Battery Replacement, Anti-Clamp instructions: step 5, image 1 of 3 iPad Pro 9.7" Battery Replacement, Anti-Clamp instructions: step 5, image 2 of 3 iPad Pro 9.7" Battery Replacement, Anti-Clamp instructions: step 5, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the top edge of the iPad—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  6. iPad Pro 9.7" Battery Replacement: step 6, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 6, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 6, image 3 of 3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    Do not use the anti clamp beyond this step. Doing so will run the risk of putting pressure on the screen and cracking it. Only use it for the initial opening of the device.
    Playincrzy - Reply
  7. iPad Pro 9.7" Battery Replacement: step 7, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 7, image 2 of 2
    • Place a suction cup over the iPad's front-facing camera and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
  8. iPad Pro 9.7" Battery Replacement: step 8, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 8, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 8, image 3 of 3
    • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
    • Do not pull too hard or you may shatter the glass.
    • Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
  9. iPad Pro 9.7" Battery Replacement: step 9, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 9, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 9, image 3 of 3
    • Slide the pick along the edge of the display, towards the headphone jack.
    • If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
    • Don't insert the pick past the bezel into the display area, or you will damage it.
    • A good rule of thumb is to never insert the opening pick more than a quarter inch into the iPad.
  10. iPad Pro 9.7" Battery Replacement: step 10, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 10, image 2 of 2
    • Insert a second opening pick by the front-facing camera.
  11. iPad Pro 9.7" Battery Replacement: step 11, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 11, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 11, image 3 of 3
    • Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
  12. iPad Pro 9.7" Battery Replacement: step 12, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 12, image 2 of 2
    • Insert a third pick by the front-facing camera.
  13. iPad Pro 9.7" Battery Replacement: step 13, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 13, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 13, image 3 of 3
    • Bring the right opening pick down and around the top right corner of the iPad.
  14. iPad Pro 9.7" Battery Replacement: step 14, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 14, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 14, image 3 of 3
    • Bring the left opening pick around the top left corner of the tablet.
  15. iPad Pro 9.7" Battery Replacement: step 15, image 1 of 1
    • Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
  16. iPad Pro 9.7" Battery Replacement: step 16, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 16, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 16, image 3 of 3
    • Slide the right opening pick roughly halfway down the display.
  17. iPad Pro 9.7" Battery Replacement: step 17, image 1 of 1
    • Reheat the iOpener and apply heat to the left side of the iPad.
  18. iPad Pro 9.7" Battery Replacement: step 18, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 18, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 18, image 3 of 3
    • Slide the left-hand opening pick about halfway down the edge of the display.
  19. iPad Pro 9.7" Battery Replacement: step 19, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 19, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 19, image 3 of 3
    • Slide the opposite opening pick down to the bottom right corner of the iPad.
    • If necessary, reheat the adhesive on the right edge to loosen the display assembly.
    Gerald - Reply
  20. iPad Pro 9.7" Battery Replacement: step 20, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 20, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 20, image 3 of 3
    • Slide the left-hand opening pick down the edge of the display until you reach the corner.
    Gerald - Reply
  21. iPad Pro 9.7" Battery Replacement: step 21, image 1 of 1
    • Use the iOpener to apply heat to the bottom edge of the iPad.
  22. iPad Pro 9.7" Battery Replacement: step 22, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 22, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 22, image 3 of 3
    • Bring the right-hand opening pick around the bottom corner of the iPad.
  23. iPad Pro 9.7" Battery Replacement: step 23, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 23, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 23, image 3 of 3
    • Repeat for the left-hand pick.
    • Reheat and reapply the iOpener as needed.
  24. iPad Pro 9.7" Battery Replacement: step 24, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 24, image 2 of 2
    • Remove the right-hand opening pick at the bottom of the iPad.
  25. iPad Pro 9.7" Battery Replacement: step 25, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 25, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 25, image 3 of 3
    • Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
    • Be very careful to not insert the pick more than a quarter inch into the display to avoid damaging the Home Button and display cables underneath.
  26. iPad Pro 9.7" Battery Replacement, Slice through the remaining adhesive: step 26, image 1 of 3 iPad Pro 9.7" Battery Replacement, Slice through the remaining adhesive: step 26, image 2 of 3 iPad Pro 9.7" Battery Replacement, Slice through the remaining adhesive: step 26, image 3 of 3
    • Use picks to ensure most of the adhesive has been cut through on the top, left, and bottom sides.
    • Twist the top and bottom picks to separate the display assembly from the rear case.
    • Do not attempt to remove the display—it is still attached to the rear case.
  27. iPad Pro 9.7" Battery Replacement: step 27, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 27, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 27, image 3 of 3
    • Swing the display assembly towards the right of the case, using the right edge as a hinge.
    • As you move the display assembly, make sure that the display ribbon cable is not being stressed.
    • Continue swinging the display assembly until it lays flat next to the rear case.
  28. iPad Pro 9.7" Battery Replacement, Disconnect the battery: step 28, image 1 of 1
    • Use a Phillips screwdriver to remove the eleven 1.3 mm screws securing the EMI shield.
  29. iPad Pro 9.7" Battery Replacement: step 29, image 1 of 1
    • Apply a heated iOpener to the EMI shield on the logic board for one minute.
  30. iPad Pro 9.7" Battery Replacement: step 30, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 30, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 30, image 3 of 3
    • Lift the logic board EMI shield, starting at the edge nearest the top of the iPad.
    • Slowly peel the EMI shield up from the logic board.
    • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
    • Remove the logic board EMI shield.
    Don't peel the cover as shown from a short side. Lift the long side to avoid creasing the cover so much. This way it will lie flat when you reassemble it and not look so ugly. Also, you won't have to straighten so many creases with pliers
    Jim Meyers - Reply
  31. iPad Pro 9.7" Battery Replacement: step 31, image 1 of 1
    • Use a Phillips driver to remove the 1.7 mm-long screw securing the battery connector.
    What size is this screw?
    Austin Martin - Reply
    i get 1.65mm with my calipers but the 1.3s read 1.25 on my calipers too, so probably a 1.7mm
    bunjamins -
  32. iPad Pro 9.7" Battery Replacement: step 32, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 32, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 32, image 3 of 3
    • If the EMI shield has any sharp protrusions after removal, you should flatten them before reinstalling the shield.
    • Squeeze the sharp protrusion with a pair of pliers to flatten it.
    • Repeat the process for all sharp protrusions along the edges of the EMI shield.
    Jim Meyers - Reply
  33. iPad Pro 9.7" Battery Replacement, Battery connector information: step 33, image 1 of 3 iPad Pro 9.7" Battery Replacement, Battery connector information: step 33, image 2 of 3 iPad Pro 9.7" Battery Replacement, Battery connector information: step 33, image 3 of 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
    Le connecteur de batterie est il réparable si abîmé ?
    Maverick - Reply
  34. iPad Pro 9.7" Battery Replacement, Disconnect the battery: step 34, image 1 of 3 iPad Pro 9.7" Battery Replacement, Disconnect the battery: step 34, image 2 of 3 iPad Pro 9.7" Battery Replacement, Disconnect the battery: step 34, image 3 of 3
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the left side of the logic board's battery connector at a 35 degree angle.
    • The battery blocker's right prong should slide between the left side of the logic board's battery connector and the battery's contact pads. The left prong should slide under the logic board.
    • Don't push the battery blocker underneath the connector or logic board with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, refer to the next step for information on loosening the logic board. You can also try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card should slide under the logic board without encountering any blockages. After insertion, they should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
    le connecteur de la batterie est t’il remplaçable ou repérable si jamais abîmé ?
    Maverick - Reply
  35. iPad Pro 9.7" Battery Replacement, Logic board adhesive information: step 35, image 1 of 2 iPad Pro 9.7" Battery Replacement, Logic board adhesive information: step 35, image 2 of 2
    • If the battery blocker doesn't easily slide under the logic board, follow these steps to partially loosen the logic board from the frame:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the logic board to the left and right of the battery connection.
    • Wait one minute for the isopropyl alcohol to weaken the adhesive under the logic board.
    • Try to insert the battery blocker. If the logic board doesn't easily lift up, apply a few more drops of isopropyl alcohol.
    • This doesn't apply when using the playing card method to disconnect the battery because the playing card is only inserted between the battery connector and the battery contact pads.
  36. iPad Pro 9.7" Battery Replacement, Remove the display bracket screws: step 36, image 1 of 1
    • Use a Phillips screwdriver to remove the three 1.3 mm Phillips screws securing the display cable bracket.
    i think we need to talk about the battery situation here. apple change up the style of battery connector on this model as well as some others. if someone can add to this list and add the appropriate photos in the right spot should help someone else. the battery tabs are open towards the battery side and inserting a tool in this area can pry them open further and damage or rip off the tab. some have found that by lifting on either side of the battery tab, they would not even encounter the tabs.
    greg - Reply
  37. iPad Pro 9.7" Battery Replacement, Remove the bracket: step 37, image 1 of 2 iPad Pro 9.7" Battery Replacement, Remove the bracket: step 37, image 2 of 2
    • Remove the display cable bracket.
    A tab was folded over a connector of some sort on the bottom side. I found it was a better to pull from the top to the bottom to fold the tabs slightly to remove this cover.
    rosecitymech - Reply
    Actually it helps to move the cover slightly towards the bottom of the iPad as that disengages to tabs…
    DeeAnn Hopings - Reply
  38. iPad Pro 9.7" Battery Replacement, Disconnect the display assembly: step 38, image 1 of 2 iPad Pro 9.7" Battery Replacement, Disconnect the display assembly: step 38, image 2 of 2
    • Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
  39. iPad Pro 9.7" Battery Replacement: step 39, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 39, image 2 of 2
    • Repeat the previous step for the two remaining connectors.
  40. iPad Pro 9.7" Battery Replacement, Remove the display assembly: step 40, image 1 of 2 iPad Pro 9.7" Battery Replacement, Remove the display assembly: step 40, image 2 of 2
    You "CAN" skip steps 41 through 98 and 102-109 if you're confident in your repair abilities and PATIENT. Lots of alcohol around all the edges of the battery, and apply heat to the back cover on one half of the battery, the slowly ease your "card under the edges of the battery. Wiggle it back and forth and add more alcohol under the edges of the battery where your working; DONT PUSH your card to hard or you will sli[p and damage components. Then do the same for the other half. When both halves are loose, fold over one end and slide the flat edge off the spudger under the area of the logic board next to the battery connector, then do the same to the other side; you want just enough of a gap under the logic board to lift the battery tab off of the post then you can remove the battery.
    Gregg Stanley - Reply
    ディスプレイアッセンブリを外して、黒くて古い接着テープをはがしすためにぴっぱったら、ディスプレイと本体基盤を接続するコネクターのテーブを不注意で切断してしまった。これで、交換はあきらめで中止。注意されたし。ちなみに、手順41~89は省いてもバッテリー交換ができるのではないかと思います。
    susuper - Reply
  41. iPad Pro 9.7" Battery Replacement, Detach the right ambient light sensor: step 41, image 1 of 3 iPad Pro 9.7" Battery Replacement, Detach the right ambient light sensor: step 41, image 2 of 3 iPad Pro 9.7" Battery Replacement, Detach the right ambient light sensor: step 41, image 3 of 3
    • Slide an opening pick under the right ambient light sensor to loosen its adhesive.
    • There are two pegs on the shelf that position the ambient light sensor—one on the bottom edge and one near the top edge.
    The "right ambient light sensor" can be replaced?
    If yes, where can I find the replacement part?
    Michael Rodriguez - Reply
    The light sensor has a rubber collar. If you lift the cover you can see a tiny peg pushed upwards onto the bottom of the sensor base. It’s the base you need to lift and it is stuck down
    Gerald - Reply
  42. iPad Pro 9.7" Battery Replacement, Remove the four screws: step 42, image 1 of 1
    • Use a Phillips screwdriver to remove the four 1.9 mm-long screws securing the upper speaker to the frame.
  43. iPad Pro 9.7" Battery Replacement, Apply isopropyl alcohol: step 43, image 1 of 2 iPad Pro 9.7" Battery Replacement, Apply isopropyl alcohol: step 43, image 2 of 2
    • Strong adhesive secures the upper speaker to the frame.
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the upper speaker.
    • Wait one minute for the isopropyl alcohol to weaken the adhesive under the upper speaker.
  44. iPad Pro 9.7" Battery Replacement, Pry up the upper speaker: step 44, image 1 of 2 iPad Pro 9.7" Battery Replacement, Pry up the upper speaker: step 44, image 2 of 2
    • Use an opening tool to pry up the left edge of the upper speaker.
    • Try to avoid bending the upper speaker while prying it up. Some bending will likely happen during this process, but excessive bending may damage the upper speaker.
    • If the upper speaker isn't detaching from the frame, apply a few more drops of isopropyl alcohol.
    These next 3 steps are the most difficult of the whole process. The speaker is glued down along its whole length which must all be freed. Use the iopener underneath the top of the iPad whilst you are waiting for the alcohol to work to help soften the glue.
    On the left hand side, there is a flat cable glued to the back plate and the speaker is then glued on top of the cable. So when you put the alcohol down it’s most likely to deboned the cable which will remain attached to the speaker as you lever it up and need carefully separating somehow.
    There is a zif connector on that cable underneath the speaker and just to the left of the front facing camera so there’s not much play. If you are unable to remove cable from the bottom of the speaker, you’ll pull the cable out of the connector as you lift the speaker. Don’t lever the speaker downwards (next step) until this zif connector is detached or you’re trash the connector itself.
    There’s also a round wire which passes underneath the speaker, that’s a bit stronger.
    Gerald - Reply
  45. iPad Pro 9.7" Battery Replacement, Move the left side of the upper speaker: step 45, image 1 of 2 iPad Pro 9.7" Battery Replacement, Move the left side of the upper speaker: step 45, image 2 of 2
    • Use the flat end of a spudger to push the left side of the upper speaker toward the battery just enough for the left speaker to slide out of its recess in the frame.
    The external speaker (headphone socket) on the left side of the speaker must be removed. 2 screws for the cover, 1 for the socket support. As well as a sensor of some sort. The cover for the sensor came off separately.
    Rogie B - Reply
    I didn’t remove that speaker but doing so may give to more access to lift the speaker unit upwards.
    DO NOT move the speaker downwards until you have completely separated the speaker from the flat cable glued to the bottom of it on the left hand side or disconnected the zif connector. See my comment in previous step.
    Gerald - Reply
  46. iPad Pro 9.7" Battery Replacement, Remove the upper speaker: step 46, image 1 of 2 iPad Pro 9.7" Battery Replacement, Remove the upper speaker: step 46, image 2 of 2
    • Lift and remove the upper speaker from the frame.
    • There are multiple cables under the upper speaker. Be careful not to damage them while removing it.
    • If any cables are still attached to the upper speaker while you lift it up, carefully peel them off of the upper speaker. You can apply more isopropyl alcohol if they don't easily peel away.
    • If the ZIF connector sticker near the front camera comes off while removing the upper speaker, reapply it to the ZIF connector.
    • If the ZIF connector near the front camera disconnects while removing the upper speaker, use the pointed end of a spudger to flip up the locking flap. Then, reinsert the ribbon cable and close the locking flap.
    • During reassembly, make sure the right ambient light sensor is on top of its shelf.
    • If there's any alcohol solution remaining in the device, carefully wipe it off or allow it to air dry before reinstalling the upper speaker.
    You are going to disconnect the zif connector later. If it’s popped out there’s not need to put it back.
    Gerald - Reply
  47. iPad Pro 9.7" Battery Replacement, Disconnect the right antenna: step 47, image 1 of 2 iPad Pro 9.7" Battery Replacement, Disconnect the right antenna: step 47, image 2 of 2
    • Use the flat end of a spudger to disconnect the right antenna's coaxial connector from its socket.
    • To reinstall, hold the connector in place and gently press straight down. The connector will “snap” into its socket.
  48. iPad Pro 9.7" Battery Replacement, Disconnect the left antenna: step 48, image 1 of 2 iPad Pro 9.7" Battery Replacement, Disconnect the left antenna: step 48, image 2 of 2
    • Use the flat end of a spudger to disconnect the left antenna's coaxial connector from its socket.
  49. iPad Pro 9.7" Battery Replacement, Lift the antenna cables: step 49, image 1 of 2 iPad Pro 9.7" Battery Replacement, Lift the antenna cables: step 49, image 2 of 2
    • Use the flat end of a spudger to lift the bundled left and right antenna cables away from the frame.
    • Be careful not to puncture the battery with the spudger.
    • The sticker bundling the antenna cables together is lightly adhered to the frame.
  50. iPad Pro 9.7" Battery Replacement, Remove the adhesive: step 50, image 1 of 1
    • Use a pair of tweezers to remove the adhesive that was securing the bundled antenna cables to the frame.
    • Take care not to damage the antenna cables with the sharp tips on the tweezers.
    • During reassembly, apply pre-cut adhesive to the bundled antenna cables to secure them to the frame.
  51. iPad Pro 9.7" Battery Replacement, Separate the antenna cables: step 51, image 1 of 2 iPad Pro 9.7" Battery Replacement, Separate the antenna cables: step 51, image 2 of 2
    • Use a pair of tweezers to peel up the sticker bundling the left and right antenna cables together.
  52. iPad Pro 9.7" Battery Replacement: step 52, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 52, image 2 of 2
    • Peel the right antenna cable off of the sticker.
  53. iPad Pro 9.7" Battery Replacement, Lift up the small sticker: step 53, image 1 of 2 iPad Pro 9.7" Battery Replacement, Lift up the small sticker: step 53, image 2 of 2
    • Use a pair of tweezers to lift up the small sticker near the lower right speaker securing the right antenna to the frame.
  54. iPad Pro 9.7" Battery Replacement, Detach the foam spacer: step 54, image 1 of 3 iPad Pro 9.7" Battery Replacement, Detach the foam spacer: step 54, image 2 of 3 iPad Pro 9.7" Battery Replacement, Detach the foam spacer: step 54, image 3 of 3
    • Use the pointed end of a spudger to detach the foam spacer adhered to the second right antenna sticker.
  55. iPad Pro 9.7" Battery Replacement, Remove the foam spacer: step 55, image 1 of 1
    • Remove the foam spacer from the second right antenna sticker.
  56. iPad Pro 9.7" Battery Replacement, Detach the large sticker: step 56, image 1 of 2 iPad Pro 9.7" Battery Replacement, Detach the large sticker: step 56, image 2 of 2
    • Use a pair of tweezers to detach the large right antenna sticker between the logic board and the antenna.
  57. iPad Pro 9.7" Battery Replacement, Lift up the first sticker: step 57, image 1 of 2 iPad Pro 9.7" Battery Replacement, Lift up the first sticker: step 57, image 2 of 2
    • Use a pair of tweezers to lift up the small sticker next to the lower right speaker securing the left antenna cable to the frame.
  58. iPad Pro 9.7" Battery Replacement, Detach the second sticker: step 58, image 1 of 2 iPad Pro 9.7" Battery Replacement, Detach the second sticker: step 58, image 2 of 2
    • Use a pair of tweezers to detach the large left antenna cable sticker near the lower right speaker.
  59. iPad Pro 9.7" Battery Replacement, Lift up the third sticker: step 59, image 1 of 2 iPad Pro 9.7" Battery Replacement, Lift up the third sticker: step 59, image 2 of 2
    • Use a pair of tweezers to lift the left antenna and its third sticker away from the Lightning port area of the frame.
  60. iPad Pro 9.7" Battery Replacement, Detach the foam spacer: step 60, image 1 of 3 iPad Pro 9.7" Battery Replacement, Detach the foam spacer: step 60, image 2 of 3 iPad Pro 9.7" Battery Replacement, Detach the foam spacer: step 60, image 3 of 3
    • Use the pointed end of a spudger to detach the foam spacer adhered to the fourth left antenna cable sticker.
  61. iPad Pro 9.7" Battery Replacement, Remove the foam spacer: step 61, image 1 of 1
    • Remove the foam spacer from the fourth left antenna cable sticker.
  62. iPad Pro 9.7" Battery Replacement: step 62, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 62, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 62, image 3 of 3
    • Use a pair of tweezers to lift up the fourth left antenna cable sticker.
  63. iPad Pro 9.7" Battery Replacement, Remove the left ambient light sensor's sticker: step 63, image 1 of 1
    • Use a pair of tweezers to remove the sticker covering the left ambient light sensor's ZIF connector.
    Der ZIF Stecker liegt versteckt unter der GSM/LTE Antenne.
    Bernd Löhr - Reply
  64. iPad Pro 9.7" Battery Replacement, Unlatch the ZIF connector: step 64, image 1 of 2 iPad Pro 9.7" Battery Replacement, Unlatch the ZIF connector: step 64, image 2 of 2
    • Use the pointed end of a spudger to flip up the locking flap on the left ambient light sensor's ZIF connector.
  65. iPad Pro 9.7" Battery Replacement, Disconnect the left ambient light sensor: step 65, image 1 of 2 iPad Pro 9.7" Battery Replacement, Disconnect the left ambient light sensor: step 65, image 2 of 2
    • Use a pair of tweezers to grip the left ambient light sensor ribbon cable as close as possible to its contacts.
    • Pull the ribbon cable out of the ZIF connector.
  66. iPad Pro 9.7" Battery Replacement, Disconnect the front camera: step 66, image 1 of 2 iPad Pro 9.7" Battery Replacement, Disconnect the front camera: step 66, image 2 of 2
    • Use the pointed end of a spudger to disconnect the front camera's press connector from its socket.
    • Be careful to pry only under the edge of the connector, and not under the socket itself. If you pry under the socket, you will separate it from the circuit board.
    • To reconnect, align the connector carefully over its socket and press down with your fingertip—first at one side, then the other—until it clicks into place.
    • Do not press down on the middle until the connector is fully seated—if it's misaligned, the connector can bend, causing permanent damage.
  67. iPad Pro 9.7" Battery Replacement, Disconnect the coaxial connector: step 67, image 1 of 2 iPad Pro 9.7" Battery Replacement, Disconnect the coaxial connector: step 67, image 2 of 2
    • Use a pair of tweezers to grip the bottom coaxial connector on the top interconnect board by its metal frame.
    • Lift straight up to disconnect the coaxial connector from the interconnect board.
    I got to this step and the connector separated from the tiny interconnect board. Is there a way to jump these cables without that board?
    John Bauldree - Reply
  68. iPad Pro 9.7" Battery Replacement, Apply isopropyl alcohol: step 68, image 1 of 2 iPad Pro 9.7" Battery Replacement, Apply isopropyl alcohol: step 68, image 2 of 2
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the edges of the top interconnect board.
    • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive under the top interconnect board.
  69. iPad Pro 9.7" Battery Replacement, Detach the top interconnect board: step 69, image 1 of 2 iPad Pro 9.7" Battery Replacement, Detach the top interconnect board: step 69, image 2 of 2
    • Use an opening pick to cut through the adhesive under the top interconnect board and detach it from the frame.
  70. iPad Pro 9.7" Battery Replacement, Disconnect the rear camera: step 70, image 1 of 2 iPad Pro 9.7" Battery Replacement, Disconnect the rear camera: step 70, image 2 of 2
    • Use the pointed end of a spudger to disconnect the rear camera's press connector from its socket.
  71. iPad Pro 9.7" Battery Replacement, Disconnect the power button assembly: step 71, image 1 of 2 iPad Pro 9.7" Battery Replacement, Disconnect the power button assembly: step 71, image 2 of 2
    • Use the pointed end of a spudger to disconnect the power button assembly's press connector from its socket.
  72. iPad Pro 9.7" Battery Replacement, Disconnect the volume buttons: step 72, image 1 of 2 iPad Pro 9.7" Battery Replacement, Disconnect the volume buttons: step 72, image 2 of 2
    • Use the pointed end of a spudger to disconnect the volume buttons' press connector from its socket.
  73. iPad Pro 9.7" Battery Replacement, Remove the sticker from the ZIF connectors: step 73, image 1 of 2 iPad Pro 9.7" Battery Replacement, Remove the sticker from the ZIF connectors: step 73, image 2 of 2
    • Use a pair of tweezers to remove the sticker covering the ZIF connectors near the Lightning port.
  74. iPad Pro 9.7" Battery Replacement, Detach the right ribbon cable: step 74, image 1 of 2 iPad Pro 9.7" Battery Replacement, Detach the right ribbon cable: step 74, image 2 of 2
    • Use an opening pick to cut through the adhesive under the right ribbon cable next to the lower speaker (Lightning port oriented up) and detach it from the frame.
    • Be careful not to pull the ribbon cable out of the ZIF connector. Pulling the ribbon cable out while the ZIF connector locking flap is closed may damage the connection.
  75. iPad Pro 9.7" Battery Replacement, Detach the left ribbon cable: step 75, image 1 of 2 iPad Pro 9.7" Battery Replacement, Detach the left ribbon cable: step 75, image 2 of 2
    • Use an opening pick to cut through the adhesive under the left ribbon cable next to the lower speaker and detach it from the frame.
  76. iPad Pro 9.7" Battery Replacement, Disconnect the ribbon cables: step 76, image 1 of 2 iPad Pro 9.7" Battery Replacement, Disconnect the ribbon cables: step 76, image 2 of 2
    • Use the pointed end of a spudger to flip up the hinged locking flap on the left ribbon cable ZIF connector.
  77. iPad Pro 9.7" Battery Replacement: step 77, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 77, image 2 of 2
    • Use the pointed end of a spudger to flip up the hinged locking flap on the right ribbon cable ZIF connector.
  78. iPad Pro 9.7" Battery Replacement: step 78, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 78, image 2 of 2
    • Use a pair of tweezers to grip the left ribbon cable as close as possible to its contacts and pull the ribbon cable out of the ZIF connector.
  79. iPad Pro 9.7" Battery Replacement: step 79, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 79, image 2 of 2
    • Use a pair of tweezers to grip the right ribbon cable as close as possible to its contacts and pull the ribbon cable out of the ZIF connector.
  80. iPad Pro 9.7" Battery Replacement, Remove the Lightning port screws: step 80, image 1 of 1
    • Remove the four Phillips screws securing the Lightning port:
    • Two 2.5 mm screws
    • Two 1.5 mm screws
  81. iPad Pro 9.7" Battery Replacement, Logic board adhesive information: step 81, image 1 of 2 iPad Pro 9.7" Battery Replacement, Logic board adhesive information: step 81, image 2 of 2
    • This image shows the device with the logic board removed.
    • Strips of adhesive secure the logic board to the frame. In the next steps, you'll weaken and cut through the adhesive to detach the logic board from the frame.
  82. iPad Pro 9.7" Battery Replacement, Apply an iOpener to the rear case: step 82, image 1 of 3 iPad Pro 9.7" Battery Replacement, Apply an iOpener to the rear case: step 82, image 2 of 3 iPad Pro 9.7" Battery Replacement, Apply an iOpener to the rear case: step 82, image 3 of 3
    • Carefully turn the iPad over.
    • Many cables are loose at this point. Make sure no cables are bent or torn while turning the iPad over.
    • Heat an iOpener and apply it to the top, left, and bottom edges of the rear case for one minute on each edge.
  83. iPad Pro 9.7" Battery Replacement, Detach the Lightning port ribbon cable: step 83, image 1 of 2 iPad Pro 9.7" Battery Replacement, Detach the Lightning port ribbon cable: step 83, image 2 of 2
    • Use an opening pick to cut through the adhesive under the Lightning port ribbon cable to detach it from the frame.
  84. iPad Pro 9.7" Battery Replacement, Lift up the stickers: step 84, image 1 of 2 iPad Pro 9.7" Battery Replacement, Lift up the stickers: step 84, image 2 of 2
    • Use a pair of tweezers to lift up the smaller sticker to the left of the Lightning port (when the Lightning port is oriented up).
  85. iPad Pro 9.7" Battery Replacement: step 85, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 85, image 2 of 2
    • Use a pair of tweezers to lift up the larger sticker to the left of the Lightning port.
  86. iPad Pro 9.7" Battery Replacement, Pull the Lightning port out: step 86, image 1 of 2 iPad Pro 9.7" Battery Replacement, Pull the Lightning port out: step 86, image 2 of 2
    • Use a pair of tweezers to grip the Lightning port by the bottom right screw hole.
    • Pull the Lightning port out of its recess.
  87. iPad Pro 9.7" Battery Replacement, Apply isopropyl alcohol: step 87, image 1 of 1
    • Apply a few drops of high-concentration isopropyl alcohol under the left edge of the upper logic board arm (Lightning port oriented down).
    • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive under the upper logic board arm.
  88. iPad Pro 9.7" Battery Replacement, Cut through the adhesive under the upper arm: step 88, image 1 of 2 iPad Pro 9.7" Battery Replacement, Cut through the adhesive under the upper arm: step 88, image 2 of 2
    • Use an opening pick to cut through the adhesive under the upper logic board arm and detach it from the frame.
    • The upper logic board arm is thin. Be careful not to tear it during this process.
    • It may help to grip the upper logic board arm with your fingers and peel it away from the frame.
    • Apply a few more drops of isopropyl alcohol under the logic board arm when it becomes difficult to detach from the frame.
  89. iPad Pro 9.7" Battery Replacement: step 89, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 89, image 2 of 2
    • Insert an opening pick about 0.5 inches (13 mm) under the top edge of the larger portion of the upper logic board arm.
    • Leave the opening pick under the upper logic board arm to prevent it from re-adhering to the frame.
  90. iPad Pro 9.7" Battery Replacement, Apply isopropyl alcohol: step 90, image 1 of 2 iPad Pro 9.7" Battery Replacement, Apply isopropyl alcohol: step 90, image 2 of 2
    • Apply a few drops of high-concentration isopropyl alcohol to the right edge of the logic board.
  91. iPad Pro 9.7" Battery Replacement: step 91, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 91, image 2 of 2
    • Apply a few drops of high-concentration isopropyl alcohol to the left edge of the logic board.
  92. iPad Pro 9.7" Battery Replacement, Cut through the adhesive under the logic board: step 92, image 1 of 2 iPad Pro 9.7" Battery Replacement, Cut through the adhesive under the logic board: step 92, image 2 of 2
    • Slide an opening pick about 0.5 inches (13 mm) under the top of the logic board's left side to cut through the adhesive.
    • Remove the opening pick.
  93. iPad Pro 9.7" Battery Replacement: step 93, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 93, image 2 of 2
    • Slide the opening pick about 0.5 inches (13 mm) under the logic board's left side next to the battery connector.
  94. iPad Pro 9.7" Battery Replacement: step 94, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 94, image 2 of 2
    • Slide the opening pick about 0.5 inches (13 mm) under the logic board on the other side of the battery connector.
  95. iPad Pro 9.7" Battery Replacement: step 95, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 95, image 2 of 2
    • Slide the opening pick about 0.5 inches (13 mm) under the bottom of the logic board's left side.
  96. iPad Pro 9.7" Battery Replacement, Remove the battery blocker: step 96, image 1 of 2 iPad Pro 9.7" Battery Replacement, Remove the battery blocker: step 96, image 2 of 2
    • Remove the battery blocker from the logic board.
    • During reassembly, reinsert the battery blocker after you install the logic board into the device.
  97. iPad Pro 9.7" Battery Replacement, Remove the opening pick: step 97, image 1 of 2 iPad Pro 9.7" Battery Replacement, Remove the opening pick: step 97, image 2 of 2
    • Remove the opening pick from the upper logic board arm.
  98. iPad Pro 9.7" Battery Replacement, Remove the logic board: step 98, image 1 of 3 iPad Pro 9.7" Battery Replacement, Remove the logic board: step 98, image 2 of 3 iPad Pro 9.7" Battery Replacement, Remove the logic board: step 98, image 3 of 3
    • Remove the logic board from the frame.
    • If the logic board doesn't easily lift out of the frame, apply a few more drops of isopropyl alcohol to any stuck areas and use an opening pick to cut through more of the adhesive.
    • If there's any alcohol solution remaining in the device, carefully wipe it off or allow it to air dry before installing your logic board.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to secure the logic board to the frame.
  99. iPad Pro 9.7" Battery Replacement, Lift the tape covering the Smart Connector: step 99, image 1 of 2 iPad Pro 9.7" Battery Replacement, Lift the tape covering the Smart Connector: step 99, image 2 of 2
    • Take care not to puncture or bend the battery—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Use tweezers to gently lift the end of the black tape covering the mid-battery circuit board nearest the Smart Connector.
    • You only need to peel the tape back enough to reveal the connector underneath.
  100. iPad Pro 9.7" Battery Replacement, Remove the screw securing the smart connector cable cover: step 100, image 1 of 2 iPad Pro 9.7" Battery Replacement, Remove the screw securing the smart connector cable cover: step 100, image 2 of 2
    • Remove the 1.7 mm Phillips screw holding the Smart Connector cable cover in place.
    • Remove the Smart Connector cable cover.
  101. iPad Pro 9.7" Battery Replacement, Disconnect the smart connector: step 101, image 1 of 3 iPad Pro 9.7" Battery Replacement, Disconnect the smart connector: step 101, image 2 of 3 iPad Pro 9.7" Battery Replacement, Disconnect the smart connector: step 101, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the Smart Connector from its socket between the battery cells.
    • Push the Smart Connector flex cable up and out of the way.
  102. iPad Pro 9.7" Battery Replacement, Apply tape to the components near the battery: step 102, image 1 of 3 iPad Pro 9.7" Battery Replacement, Apply tape to the components near the battery: step 102, image 2 of 3 iPad Pro 9.7" Battery Replacement, Apply tape to the components near the battery: step 102, image 3 of 3
    • The next three steps detail how to mask off the iPad in preparation for the liquid adhesive remover. The tape will help block and absorb excess liquids, keeping major components safe.
    • Apply a piece of masking or painter's tape to the upper components. The edge of the tape should be close to, but not touching, the battery.
    • Press down on the tape so that it adheres firmly to the frame and components.
    These steps are a good precaution, but I’m not sure they’re necessary. I found that a very stingy application of acetone — just enough to draw a line along the card with a syringe was enough to separate the adhesive, without any issues of pooling.
  103. iPad Pro 9.7" Battery Replacement: step 103, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 103, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 103, image 3 of 3
    • Repeat the taping procedure for the rear camera and volume button area.
  104. iPad Pro 9.7" Battery Replacement: step 104, image 1 of 3 iPad Pro 9.7" Battery Replacement: step 104, image 2 of 3 iPad Pro 9.7" Battery Replacement: step 104, image 3 of 3
    • Repeat the taping procedure for the lower components.
  105. iPad Pro 9.7" Battery Replacement, Tape and battery adhesive information: step 105, image 1 of 2 iPad Pro 9.7" Battery Replacement, Tape and battery adhesive information: step 105, image 2 of 2
    • Once complete, the masking should look like the first image.
    • The adhesive remover may discolor or damage plastic components such as the speaker housings. Make sure you have applied the tape properly before you continue.
    • Four strips of strong adhesive hold the battery in place.
  106. iPad Pro 9.7" Battery Replacement, Set up a place to tilt the iPad: step 106, image 1 of 2 iPad Pro 9.7" Battery Replacement, Set up a place to tilt the iPad: step 106, image 2 of 2
    • Prepare a work area where the iPad can rest in a tilted position, to allow adhesive remover to trickle down to the adhesive strips.
    • You can use books, boxes, etc. as long as they will not move.
  107. iPad Pro 9.7" Battery Replacement, Adhesive remover safety information: step 107, image 1 of 2 iPad Pro 9.7" Battery Replacement, Adhesive remover safety information: step 107, image 2 of 2
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are highly recommended beyond this step, as the dissolved adhesive will be very tacky and hard to wash off.
  108. iPad Pro 9.7" Battery Replacement, Adhesive remover opening information: step 108, image 1 of 3 iPad Pro 9.7" Battery Replacement, Adhesive remover opening information: step 108, image 2 of 3 iPad Pro 9.7" Battery Replacement, Adhesive remover opening information: step 108, image 3 of 3
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  109. iPad Pro 9.7" Battery Replacement, Make a gap for the adhesive remover: step 109, image 1 of 3 iPad Pro 9.7" Battery Replacement, Make a gap for the adhesive remover: step 109, image 2 of 3 iPad Pro 9.7" Battery Replacement, Make a gap for the adhesive remover: step 109, image 3 of 3
    Plastic Cards
    $2.99
    Buy
    • Carefully insert a plastic card under the bottom right corner of the battery.
    • Slowly slide the plastic card across the bottom edge of the battery to make a gap for the liquid adhesive remover.
    • At this point, you do not need to push the card very deep under the battery. 0.5 inches (13 mm) is more than sufficient.
    • While some bending of the battery pack will be inevitable, try not to form any sharp creases, which will compromise the battery structure and potentially trigger a fire hazard.
  110. iPad Pro 9.7" Battery Replacement, Apply adhesive remover to the bottom of the battery: step 110, image 1 of 3 iPad Pro 9.7" Battery Replacement, Apply adhesive remover to the bottom of the battery: step 110, image 2 of 3 iPad Pro 9.7" Battery Replacement, Apply adhesive remover to the bottom of the battery: step 110, image 3 of 3
    • Tilt the bottom of the iPad up.
    • Apply a few drops of adhesive remover evenly along the elevated edge of the battery.
    • A little bit goes a long way, so start with a very small amount. You can always add more later if needed. Applying the solvent in small amounts helps prevent unwanted leaks.
  111. iPad Pro 9.7" Battery Replacement, Allow the adhesive remover to soften the adhesive: step 111, image 1 of 1
    • Rest the iPad in a slanted position, bottom edge up, and wait 2-3 minutes to allow the adhesive remover to penetrate and soften the first adhesive strip.
  112. iPad Pro 9.7" Battery Replacement, Slice through the adhesive strip: step 112, image 1 of 3 iPad Pro 9.7" Battery Replacement, Slice through the adhesive strip: step 112, image 2 of 3 iPad Pro 9.7" Battery Replacement, Slice through the adhesive strip: step 112, image 3 of 3
    • Slide a plastic card into the bottom edge of the battery.
    • Push the card in slowly and firmly. Gently wiggle and twist the card to help it slice through the adhesive.
    • If you are struggling, tilt the iPad, apply a few more drops of adhesive remover and wait a minute before trying again.
  113. iPad Pro 9.7" Battery Replacement, Alternate prying approach information: step 113, image 1 of 3 iPad Pro 9.7" Battery Replacement, Alternate prying approach information: step 113, image 2 of 3 iPad Pro 9.7" Battery Replacement, Alternate prying approach information: step 113, image 3 of 3
    • You can also approach the adhesive strip with the plastic card from battery's other bottom corner.
    • Continue slicing until you have separated the battery from the first adhesive strip.
  114. iPad Pro 9.7" Battery Replacement, Repeat the application, waiting, and slicing process: step 114, image 1 of 3 iPad Pro 9.7" Battery Replacement, Repeat the application, waiting, and slicing process: step 114, image 2 of 3 iPad Pro 9.7" Battery Replacement, Repeat the application, waiting, and slicing process: step 114, image 3 of 3
    • Reapply adhesive remover into the gap for the second adhesive strip, located deeper underneath the bottom battery cell.
    • Repeat the application, waiting, and slicing process until the second adhesive strip is separated from the battery.
  115. iPad Pro 9.7" Battery Replacement, Create a gap for the adhesive remover: step 115, image 1 of 3 iPad Pro 9.7" Battery Replacement, Create a gap for the adhesive remover: step 115, image 2 of 3 iPad Pro 9.7" Battery Replacement, Create a gap for the adhesive remover: step 115, image 3 of 3
    • Slide an opening pick under the top edge of the battery, creating a gap large enough for a plastic card.
    • Insert a plastic card under the top edge and slide it across the entire length, creating a gap for the adhesive remover.
  116. iPad Pro 9.7" Battery Replacement, Apply adhesive remover to the top of the battery: step 116, image 1 of 3 iPad Pro 9.7" Battery Replacement, Apply adhesive remover to the top of the battery: step 116, image 2 of 3 iPad Pro 9.7" Battery Replacement, Apply adhesive remover to the top of the battery: step 116, image 3 of 3
    • Apply adhesive remover into the gap to help weaken the third adhesive strip.
  117. iPad Pro 9.7" Battery Replacement, Allow the adhesive remover to soften the adhesive: step 117, image 1 of 1
    • Rest the iPad in a slanted position, top edge up, for 2-3 minutes to allow the adhesive remover to weaken the third strip.
  118. iPad Pro 9.7" Battery Replacement, Slice through the adhesive strip: step 118, image 1 of 3 iPad Pro 9.7" Battery Replacement, Slice through the adhesive strip: step 118, image 2 of 3 iPad Pro 9.7" Battery Replacement, Slice through the adhesive strip: step 118, image 3 of 3
    • Use a plastic card to slice through the third adhesive strip.
    • If you are struggling, tilt the iPad, apply a few more drops of adhesive remover, and wait a minute before trying again.
  119. iPad Pro 9.7" Battery Replacement, Repeat the application, waiting, and slicing process: step 119, image 1 of 3 iPad Pro 9.7" Battery Replacement, Repeat the application, waiting, and slicing process: step 119, image 2 of 3 iPad Pro 9.7" Battery Replacement, Repeat the application, waiting, and slicing process: step 119, image 3 of 3
    • Repeat the application, waiting, and slicing process to release the last adhesive strip located deeper underneath the top battery cell.
  120. iPad Pro 9.7" Battery Replacement, Flip the bottom half of the battery over: step 120, image 1 of 3 iPad Pro 9.7" Battery Replacement, Flip the bottom half of the battery over: step 120, image 2 of 3 iPad Pro 9.7" Battery Replacement, Flip the bottom half of the battery over: step 120, image 3 of 3
    • Use the plastic card or your fingers to flip the bottom half of the battery over so that it rests on top of the upper half.
  121. iPad Pro 9.7" Battery Replacement, Slice through the adhesive under the circuit board: step 121, image 1 of 2 iPad Pro 9.7" Battery Replacement, Slice through the adhesive under the circuit board: step 121, image 2 of 2
    • The end of the mid-battery circuit board closer to the Smart Connector is held down with adhesive.
    • Slide an opening pick underneath the mid-battery circuit board, near the Smart Connector.
    • Carefully slice underneath the board around the post to release the board from the rear case.
  122. iPad Pro 9.7" Battery Replacement: step 122, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 122, image 2 of 2
    • Slide the long edge of a plastic card about 0.5 inches (13 mm) under the center of the mid-battery circuit board to cut through the remaining adhesive.
  123. iPad Pro 9.7" Battery Replacement, Remove the battery: step 123, image 1 of 1
    • Lift and remove the battery from the frame.
    • Two screw posts position the battery on the frame—one near the Smart Connector and one under the battery connector.
  124. iPad Pro 9.7" Battery Replacement, Replacement battery installation information: step 124, image 1 of 2 iPad Pro 9.7" Battery Replacement, Replacement battery installation information: step 124, image 2 of 2
    • The next steps detail how to install a new battery. Never reinstall a used battery.
    • Thoroughly clean the back case of all adhesive residue.
    • Apply adhesive remover or high concentration (over 90%) isopropyl alcohol to the residue.
    • Use an opening tool to scrape and loosen the residue.
    • Be sure to wipe the residue away in one direction to prevent smearing.
    • It is easier to wipe off the residue when it is sufficiently soaked. Once it starts drying up, the residue becomes incredibly tacky.
    • If you used adhesive remover, be sure to wipe the surface down with isopropyl alcohol to remove any adhesive remover residue.
    • You can remove the masking tape as well as any protective gear once you are done cleaning.
  125. iPad Pro 9.7" Battery Replacement: step 125, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 125, image 2 of 2
    • Place the replacement battery pack so that the two screw posts line up with their holes on the mid-battery circuit board and battery connector.
  126. iPad Pro 9.7" Battery Replacement: step 126, image 1 of 2 iPad Pro 9.7" Battery Replacement: step 126, image 2 of 2
    • Lift the bottom edge of the battery up slightly.
    • Do not hinge the battery beyond 45 degrees, or you risk damaging the inter-cell connectors.
    • Use tweezers or your fingers to peel the single clear plastic covering off of the entire bottom side of the battery.
    • At this point, the battery's four adhesive strips are exposed. Be careful handling the battery and try not to touch the strips.
    • Align the battery such that it falls in place with the screw post near the Smart Connector.
    • Be sure not to trap the Smart Connector cable underneath the battery.
    • Gently lay the battery down into its recess and press it firmly into place.
    • For optimal performance, calibrate your newly installed battery after completing this guide: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our iPad Pro 9.7” Answers Community for troubleshooting help.
34 other people completed this guide.
Kyle Smith
40,780 Reputation
123 Guides authored
14 Comments
That’s an excellent guide! I had to replace both the battery and the display. The iPad seems fixed and boots but shuts down after 3min/180s due to "no successful checkins from com.apple.thermalmonitord since wake". The other services listed in the dump all report successful checkins. I have no idea whether that rather indicates something went wrong with the battery replacement or with the display exchange (and associated home button transfer). A hard DFU didn’t help.
frightanic.com - Reply
Did you ever get this fixed? I’m running into the same thing.
Joseph Ferrare -
Hello, I tap the home button, Apple is very picky about the exchange. Just try the original home button if it is still available.
Michael Brandt - Reply
Used this guide it is missing the part where you need to remove the screw from the battery post. Post needs to be reissued. I have now tried 3 OEM batteries including reinstalling the existing one and all cause the iPad to go into a restart loop I think iOS 14 devices are firmware locked as all show 100mAh on Coconut Plus which probably causes the restart loops. Even completed hard reset and total factory reset however still stuck in restart loop
SpideRaY - Reply
Did you manage to fix this? I got the same result.
Joseph Ferrare -
Nice work on this! I’m still reeling a bit from how complicated this operation is, as I expected something much simpler. Other than the taping (which I didn’t need to do), I found every step to be absolutely necessary, just as you described. Thanks.
my ipad battery drained even faster after i replaced it with a new battery, may i know why?
ex abc - Reply
Sorry to hear about the trouble! If you bought an iFixit battery, please contact our customer support team and they would be happy to assist you.
Adam O'Camb -
I am sure that this repair guide was carried way to far. After opening the iPad and removing the batterie connector screw, the logic board cover and the display itself there is NO need to remove any other part on top. Only the screw for the smart connector needs then to be removed. So no antenna, no lighting connector and even no logic board or every other component needs to be removed.
Yes, only lifting up the logic board is a bit more tricky when connecting the new battery and it might even be more dangerous for the logic board than removing every component from the backplate. But from my point of view the risk taken is much greater following this guide than as I described since each (and here there are plenty unnecessary) step on top also leads into a higher risk. Since the glued down logic board is even totally removed the risk of bending it too much and braking it is still present.
Half of the steps are just useless which only leads into a higher risk of breaking something. In the end: just be careful.
Timo Mahringer - Reply
Hi Timo,
Thanks for your input! Your points are valid—the more you disassemble a device, the higher the chance for damage. In the past, our iPad guides actually did what you suggested; we instructed people to pry up the logic board and slide the battery connector out. Unfortunately, Apple began using stronger adhesives to hold the logic board. Flexing the board too much can cause solder joints on surface mount components to break, causing problems. We weighed the options during the guide writing process, and decided to revise with a longer, gentler approach. We're always on the lookout for better solutions, and will update the guide when we find them!
Arthur Shi -
I was wondering the same thing. Regardless of what method you use, a LOT of care is required. It seems like if you skip the logic board stuff you can probably do the repair in less than an hour. I am curious if the use of more heat on the logic board adhesive (from the back of the ipad) would be helpful.
joshcorey -
Too late for me! I managed to do all the steps and installed a new battery – but after assembly, the screen turns on (white), starts flashing and the iPad beeps. Then turns off. Switching on: the same.
I checked all connectors, display lines... Cannot see any injuries :-(
Any ideas?
Bernd Löhr - Reply
Not worth it. I’m doing a lot of repairs myself but had no inclination to go through this complicated process, so I gave the iPad to a professional repair shop (Apple certified).
As already mentioned in other comments the iPad came back with a wildly inaccurate charge indication. This seems due to the fact that the battery management system (BMS) isn’t part of the battery itself and can’t be properly reset for use with a new battery by a third party.
When reading battery parameters with coconutBattery only the cycle counter was reset, and ominously enough the indicated actual capacity was exactly the design value. SN and life cycle data were from the old battery. Charge/discharge rates weren’t shown properly and performance was a far cry from a new iPad.
Returned the iPad to the shop; they acknowledged the fault, even tried a battery from a different supplier but couldn’t fix it. Eventually they gave me a full refund.
Note: Apple already list this model as “vintage” and don’t offer battery change for it anymore.
zapotron - Reply
Awesome instructions! Worked like a charm but I would hate to go through this again!
Jennie Boudreau - Reply
Past 24 Hours: 74
Past 7 Days: 433
Past 30 Days: 2,070
All Time: 109,823
