We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
  • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
  • Place the iOpener in the center of the microwave.
  • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
Heat the iOpener for thirty seconds.
  • Heat the iOpener for thirty seconds.
  • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
  • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
  • Never touch the iOpener if it appears swollen.
  • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
  • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
  • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
New Battery = Faster iPhone
Fix Kits starting at $16.99
The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
  • The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
  • Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
  • Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step.
  • While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step.
  • As you follow the directions, take special care to avoid prying in the following areas:
    • Home Button
    • Front Facing Camera
    • Main Camera
Place a suction cup over the iPad's front-facing camera and press down to create a seal.
  • Place a suction cup over the iPad's front-facing camera and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
  • Firmly pull up on the suction cup to to create a small gap between the front panel and the rear case.
  • Do not pull too hard or you may shatter the glass.
  • Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
  • Slide the pick along the edge of the display, towards the headphone jack.
    • If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
  • Be careful not to let the opening pick slide between the fused LCD and front panel, as doing so can permanently damage the display.
    • A good rule of thumb is to never insert the opening pick more than a quarter inch into the iPad.
  • Bunch of other steps
Use one hand to prop up the display Removing the screws that secure the display cable bracket Be sure to support the weight of the display
  • Use one hand to prop up the display
  • Removing the screws that secure the display cable bracket
  • Be sure to support the weight of the display
7 other people completed this guide.
The Raptor
3,232 Reputation
8 Guides authored
Soldering will make this repair near impossible to the average.
Alec - Reply
I find this whole tutorial is misleading and that's not even mentioning step eight.
Tobey -
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 83
All Time: 2,870
