iPad Mini 3 Wi-Fi Front Panel Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini 3 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 2 of 2
    • Use the tip of a spudger to lift the digitizer cable connector straight up off of its socket.
  2. iPad Mini 3 Wi-Fi Front Panel Assembly Replacement: step 2, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Assembly Replacement: step 2, image 2 of 2
    • Slide the flat end of a spudger under the battery side of the digitizer board to begin separating it from the rear case.
  3. iPad Mini 3 Wi-Fi Front Panel Assembly Replacement: step 3, image 1 of 2 iPad Mini 3 Wi-Fi Front Panel Assembly Replacement: step 3, image 2 of 2
    • Lift the digitizer board up to free the last of the adhesive.
  4. iPad Mini 3 Wi-Fi Front Panel Assembly Replacement: step 4, image 1 of 1
    • Lift and remove the front panel assembly from the iPad.
Evan Noronha
223,409 Reputation
168 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 231
