You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Prereq only.
Parts
No parts specified.
  1. Use the tip of a spudger to peel the tape off of the antenna cables near the logic board. Use the tip of a spudger to peel the tape off of the antenna cables near the logic board.
    • Use the tip of a spudger to peel the tape off of the antenna cables near the logic board.
  2. Use the point of a spudger to separate the adhesive holding the antennas to the right speaker. Use the point of a spudger to separate the adhesive holding the antennas to the right speaker.
    • Use the point of a spudger to separate the adhesive holding the antennas to the right speaker.
  3. Use the point of a spudger to lift the antenna cable adhesive up off the rear case. Use the point of a spudger to lift the antenna cable adhesive up off the rear case.
    • Use the point of a spudger to lift the antenna cable adhesive up off the rear case.
Sam Goldheart
440,652 Reputation
547 Guides authored
iFixit Member of iFixit
Community
136 Members
16,675 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 37
