iPad Mini 3 Left Antenna Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini 3 Left Antenna Cable Replacement, Left Antenna Cable: step 1, image 1 of 1
    • Remove the following Phillips #00 screws from the left antenna:
    • One 2.6 mm screw
    • Two 1.5 mm screws
  2. iPad Mini 3 Left Antenna Cable Replacement: step 2, image 1 of 2 iPad Mini 3 Left Antenna Cable Replacement: step 2, image 2 of 2
    • Use the flat end of a spudger to loosen the foam adhesive securing the Wi-Fi antenna to the left speaker.
  3. iPad Mini 3 Left Antenna Cable Replacement: step 3, image 1 of 2 iPad Mini 3 Left Antenna Cable Replacement: step 3, image 2 of 2
    • Use the flat end of a spudger to fold the wide left-hand piece of tape away from the left speaker.
  4. iPad Mini 3 Left Antenna Cable Replacement: step 4, image 1 of 3 iPad Mini 3 Left Antenna Cable Replacement: step 4, image 2 of 3 iPad Mini 3 Left Antenna Cable Replacement: step 4, image 3 of 3
    • Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
    • Gently pull the antenna cable out of the way as you work along the piece of tape to free it and keep it from resealing.
  5. iPad Mini 3 Left Antenna Cable Replacement: step 5, image 1 of 2 iPad Mini 3 Left Antenna Cable Replacement: step 5, image 2 of 2
    • Pull the antenna cable from the clip behind the Lightning connector.
Sam Goldheart
465,656 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,734 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 87
