iPad 7 Microphone Assembly Replacement
  1. iPad 7 Microphone Assembly Replacement, Heat the left edge: step 1, image 1 of 1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 7 Microphone Assembly Replacement, Screen removal information: step 2, image 1 of 3 iPad 7 Microphone Assembly Replacement, Screen removal information: step 2, image 2 of 3 iPad 7 Microphone Assembly Replacement, Screen removal information: step 2, image 3 of 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 7 Microphone Assembly Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPad 7 Microphone Assembly Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPad 7 Microphone Assembly Replacement, Anti-Clamp instructions: step 3, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 7 Microphone Assembly Replacement: step 4, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 4, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 4, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 7 Microphone Assembly Replacement: step 5, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 5, image 2 of 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 7 Microphone Assembly Replacement, Insert an opening pick: step 6, image 1 of 3 iPad 7 Microphone Assembly Replacement, Insert an opening pick: step 6, image 2 of 3 iPad 7 Microphone Assembly Replacement, Insert an opening pick: step 6, image 3 of 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 7 Microphone Assembly Replacement, Separate the left adhesive: step 7, image 1 of 3 iPad 7 Microphone Assembly Replacement, Separate the left adhesive: step 7, image 2 of 3 iPad 7 Microphone Assembly Replacement, Separate the left adhesive: step 7, image 3 of 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 7 Microphone Assembly Replacement: step 8, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 8, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 8, image 3 of 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 7 Microphone Assembly Replacement: step 9, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 9, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 9, image 3 of 3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 7 Microphone Assembly Replacement, Heat the top edge: step 10, image 1 of 1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 7 Microphone Assembly Replacement, Separate the top left adhesive: step 11, image 1 of 3 iPad 7 Microphone Assembly Replacement, Separate the top left adhesive: step 11, image 2 of 3 iPad 7 Microphone Assembly Replacement, Separate the top left adhesive: step 11, image 3 of 3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 7 Microphone Assembly Replacement, Separate the top adhesive: step 12, image 1 of 3 iPad 7 Microphone Assembly Replacement, Separate the top adhesive: step 12, image 2 of 3 iPad 7 Microphone Assembly Replacement, Separate the top adhesive: step 12, image 3 of 3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 7 Microphone Assembly Replacement: step 13, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 13, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 13, image 3 of 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 7 Microphone Assembly Replacement: step 14, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 14, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 14, image 3 of 3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 7 Microphone Assembly Replacement, Heat the right edge: step 15, image 1 of 1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 7 Microphone Assembly Replacement, Separate the top right adhesive: step 16, image 1 of 3 iPad 7 Microphone Assembly Replacement, Separate the top right adhesive: step 16, image 2 of 3 iPad 7 Microphone Assembly Replacement, Separate the top right adhesive: step 16, image 3 of 3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 7 Microphone Assembly Replacement, Separate the right adhesive: step 17, image 1 of 3 iPad 7 Microphone Assembly Replacement, Separate the right adhesive: step 17, image 2 of 3 iPad 7 Microphone Assembly Replacement, Separate the right adhesive: step 17, image 3 of 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 7 Microphone Assembly Replacement, Heat the bottom edge: step 18, image 1 of 1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 7 Microphone Assembly Replacement, Separate the bottom left adhesive: step 19, image 1 of 3 iPad 7 Microphone Assembly Replacement, Separate the bottom left adhesive: step 19, image 2 of 3 iPad 7 Microphone Assembly Replacement, Separate the bottom left adhesive: step 19, image 3 of 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 7 Microphone Assembly Replacement, Separate the bottom adhesive: step 20, image 1 of 3 iPad 7 Microphone Assembly Replacement, Separate the bottom adhesive: step 20, image 2 of 3 iPad 7 Microphone Assembly Replacement, Separate the bottom adhesive: step 20, image 3 of 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 7 Microphone Assembly Replacement: step 21, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 21, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 21, image 3 of 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 7 Microphone Assembly Replacement: step 22, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 22, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 22, image 3 of 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 7 Microphone Assembly Replacement, Heat the right edge: step 23, image 1 of 1
  24. iPad 7 Microphone Assembly Replacement: step 24, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 24, image 2 of 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 7 Microphone Assembly Replacement: step 25, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 25, image 2 of 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 7 Microphone Assembly Replacement, Separate the right adhesive: step 26, image 1 of 3 iPad 7 Microphone Assembly Replacement, Separate the right adhesive: step 26, image 2 of 3 iPad 7 Microphone Assembly Replacement, Separate the right adhesive: step 26, image 3 of 3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 7 Microphone Assembly Replacement: step 27, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 27, image 2 of 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 7 Microphone Assembly Replacement, Remove the LCD: step 28, image 1 of 2 iPad 7 Microphone Assembly Replacement, Remove the LCD: step 28, image 2 of 2
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Phillips screwdriver to remove the four 4.3 mm-long screws securing the LCD to the frame.
    • Remove any tape obscuring the LCD screws.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  29. iPad 7 Microphone Assembly Replacement, Flip the LCD over: step 29, image 1 of 3 iPad 7 Microphone Assembly Replacement, Flip the LCD over: step 29, image 2 of 3 iPad 7 Microphone Assembly Replacement, Flip the LCD over: step 29, image 3 of 3
    • Don't attempt to fully remove the LCD during this step, as it's still connected by several cables at the home button end.
    • Only lift the LCD from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Lay the LCD down onto a clean, soft, lint-free surface to allow access to the display cables.
  30. iPad 7 Microphone Assembly Replacement, Disconnect the battery: step 30, image 1 of 1
    • Use a Phillips screwdriver to remove the single 2.3 mm-long screw securing the battery connector to the logic board.
  31. iPad 7 Microphone Assembly Replacement, Battery connector information: step 31, image 1 of 3 iPad 7 Microphone Assembly Replacement, Battery connector information: step 31, image 2 of 3 iPad 7 Microphone Assembly Replacement, Battery connector information: step 31, image 3 of 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  32. iPad 7 Microphone Assembly Replacement, Disconnect the battery: step 32, image 1 of 3 iPad 7 Microphone Assembly Replacement, Disconnect the battery: step 32, image 2 of 3 iPad 7 Microphone Assembly Replacement, Disconnect the battery: step 32, image 3 of 3
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
    • Leave the battery blocker in place as you work.
  33. iPad 7 Microphone Assembly Replacement, Remove the display cable bracket: step 33, image 1 of 1
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
  34. iPad 7 Microphone Assembly Replacement: step 34, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 34, image 2 of 2
    • Remove the display cable bracket.
  35. iPad 7 Microphone Assembly Replacement, Disconnect the LCD: step 35, image 1 of 2 iPad 7 Microphone Assembly Replacement, Disconnect the LCD: step 35, image 2 of 2
    • Use the flat end of a spudger to disconnect the LCD cable by lifting straight up on the press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  36. iPad 7 Microphone Assembly Replacement: step 36, image 1 of 1
    • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
  37. iPad 7 Microphone Assembly Replacement, Disconnect the home button: step 37, image 1 of 2 iPad 7 Microphone Assembly Replacement, Disconnect the home button: step 37, image 2 of 2
    • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
  38. iPad 7 Microphone Assembly Replacement: step 38, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 38, image 2 of 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
  39. iPad 7 Microphone Assembly Replacement: step 39, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 39, image 2 of 2
    • Use a pair of tweezers to carefully pull the home button ribbon cable straight out of the ZIF connector.
  40. iPad 7 Microphone Assembly Replacement, Disconnect the display cables: step 40, image 1 of 3 iPad 7 Microphone Assembly Replacement, Disconnect the display cables: step 40, image 2 of 3 iPad 7 Microphone Assembly Replacement, Disconnect the display cables: step 40, image 3 of 3
    • Use the flat end of a spudger to disconnect the two digitizer cables by lifting straight up on the press connectors.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  41. iPad 7 Microphone Assembly Replacement, Remove the vibration isolator: step 41, image 1 of 3 iPad 7 Microphone Assembly Replacement, Remove the vibration isolator: step 41, image 2 of 3 iPad 7 Microphone Assembly Replacement, Remove the vibration isolator: step 41, image 3 of 3
    • Use the flat end of a spudger to pry up the vibration isolator below the SIM card reader.
    • Take care not to puncture or tear the home button ribbon cable.
    • Remove the vibration isolator.
  42. iPad 7 Microphone Assembly Replacement: step 42, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 42, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 42, image 3 of 3
    • Use a pair of tweezers to peel the home button cable away from the rear case.
    • The cable is secured with some light adhesive.
  43. iPad 7 Microphone Assembly Replacement, Remove the front panel assembly: step 43, image 1 of 3 iPad 7 Microphone Assembly Replacement, Remove the front panel assembly: step 43, image 2 of 3 iPad 7 Microphone Assembly Replacement, Remove the front panel assembly: step 43, image 3 of 3
    Polyimide Tape
    $9.99
    Buy
    • Remove the front panel assembly.
    • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
  44. iPad 7 Microphone Assembly Replacement, Remove the upper component bracket: step 44, image 1 of 2 iPad 7 Microphone Assembly Replacement, Remove the upper component bracket: step 44, image 2 of 2
    • Carefully peel the LCD buffer tape up off of the upper component bracket.
  45. iPad 7 Microphone Assembly Replacement: step 45, image 1 of 1
    • Use a Phillips screwdriver to remove the five screws securing the upper component bracket.
    • Three 1.4 mm-long screws
    • Two 1.9 mm-long screws
  46. iPad 7 Microphone Assembly Replacement: step 46, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 46, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 46, image 3 of 3
    • Use the pointed end of a spudger to lift up the upper component bracket until you can grip it with your fingers.
    • Remove the upper component bracket.
    • You may need to peel the upper component bracket off of some tape securing it to the logic board.
  47. iPad 7 Microphone Assembly Replacement, Disconnect the front camera: step 47, image 1 of 2 iPad 7 Microphone Assembly Replacement, Disconnect the front camera: step 47, image 2 of 2
    • Use the flat end of a spudger to disconnect the front camera cable by lifting straight up on the press connector.
  48. iPad 7 Microphone Assembly Replacement, Remove the front camera: step 48, image 1 of 3 iPad 7 Microphone Assembly Replacement, Remove the front camera: step 48, image 2 of 3 iPad 7 Microphone Assembly Replacement, Remove the front camera: step 48, image 3 of 3
    • Use a spudger to lift the front camera out of its recess until you can grip it with your fingers.
    • Use the spudger to pull the adhesive foam pad away from the front camera.
  49. iPad 7 Microphone Assembly Replacement: step 49, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 49, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 49, image 3 of 3
    • Use a pair of tweezers to grip the front camera and rotate it to thread the cable through its slot in the rear case.
    • Remove the front camera.
  50. iPad 7 Microphone Assembly Replacement, Disconnect the headphone jack: step 50, image 1 of 2 iPad 7 Microphone Assembly Replacement, Disconnect the headphone jack: step 50, image 2 of 2
    • Use the flat end of a spudger to disconnect the headphone jack by lifting straight up on the press connector.
  51. iPad 7 Microphone Assembly Replacement: step 51, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 51, image 2 of 2
    • Use a pair of tweezers to peel the headphone jack up from the logic board and fold the cable out of the way.
  52. iPad 7 Microphone Assembly Replacement, Remove the cellular antennas: step 52, image 1 of 1
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the cellular antennas to the rear case.
  53. iPad 7 Microphone Assembly Replacement: step 53, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 53, image 2 of 2
    • Use a Phillips screwdriver to remove the four 1.4 mm-long screws securing the cellular antennas to the rear case.
  54. iPad 7 Microphone Assembly Replacement, Disconnect the cellular antennas: step 54, image 1 of 3 iPad 7 Microphone Assembly Replacement, Disconnect the cellular antennas: step 54, image 2 of 3 iPad 7 Microphone Assembly Replacement, Disconnect the cellular antennas: step 54, image 3 of 3
    • Use the pointed end of a spudger to disconnect the right cellular antenna coaxial cable by prying up as close to the connector as possible.
    • Disconnect the left antenna cable.
  55. iPad 7 Microphone Assembly Replacement: step 55, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 55, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 55, image 3 of 3
    • Use the flat end of a spudger to disconnect both cellular antennas by lifting straight up on their press connectors.
  56. iPad 7 Microphone Assembly Replacement, Remove the right cellular antenna: step 56, image 1 of 3 iPad 7 Microphone Assembly Replacement, Remove the right cellular antenna: step 56, image 2 of 3 iPad 7 Microphone Assembly Replacement, Remove the right cellular antenna: step 56, image 3 of 3
    • Insert the pointed end of a spudger behind the right cellular antenna bracket to dislodge it.
    • Remove the right cellular antenna from the rear case.
  57. iPad 7 Microphone Assembly Replacement: step 57, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 57, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 57, image 3 of 3
    • Peel the left cellular antenna coaxial cable up from the rear case.
    • Grip the antenna cable by the cable itself and not at its connector. Pulling coaxial cables by their connectors can break them.
  58. iPad 7 Microphone Assembly Replacement, Remove the left cellular antenna: step 58, image 1 of 3 iPad 7 Microphone Assembly Replacement, Remove the left cellular antenna: step 58, image 2 of 3 iPad 7 Microphone Assembly Replacement, Remove the left cellular antenna: step 58, image 3 of 3
    • Insert the flat end of a spudger underneath the left cellular antenna bracket and pry up to dislodge it.
    • Remove the left cellular antenna from the rear case.
  59. iPad 7 Microphone Assembly Replacement, Disconnect the microphone assembly: step 59, image 1 of 1
    • Use a Phillips screwdriver to remove the 1.4 mm-long screw securing the microphone assembly to the rear case.
  60. iPad 7 Microphone Assembly Replacement: step 60, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 60, image 2 of 2
    • Use the flat end of a spudger to disconnect the microphone cable by lifting straight up on the press connector.
  61. iPad 7 Microphone Assembly Replacement, Loosen the adhesive: step 61, image 1 of 1
    • Heat an iOpener and apply it to the microphone assembly for thirty seconds.
  62. iPad 7 Microphone Assembly Replacement, Remove the microphone assembly: step 62, image 1 of 3 iPad 7 Microphone Assembly Replacement, Remove the microphone assembly: step 62, image 2 of 3 iPad 7 Microphone Assembly Replacement, Remove the microphone assembly: step 62, image 3 of 3
    • Insert a halberd spudger behind the upper microphone to peel it away from the rear case.
    • If the microphone feels extra stuck, apply more heat and try again.
  63. iPad 7 Microphone Assembly Replacement: step 63, image 1 of 3 iPad 7 Microphone Assembly Replacement: step 63, image 2 of 3 iPad 7 Microphone Assembly Replacement: step 63, image 3 of 3
    • Insert the halberd spudger underneath the lower microphone and twist to peel it away from the rear case.
  64. iPad 7 Microphone Assembly Replacement: step 64, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 64, image 2 of 2
    • Use a pair of tweezers to pull the microphone assembly flex cable through the slot in the rear case.
  65. iPad 7 Microphone Assembly Replacement: step 65, image 1 of 2 iPad 7 Microphone Assembly Replacement: step 65, image 2 of 2
    • Remove the microphone assembly.
    • During reassembly, transfer the foam pad over to the new microphone assembly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 7 Answers community for help.
Robert Boyd
26,479 Reputation
94 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 268
