iON SnapCam 1045 Wearable HD Video Camera Battery
  1. iON SnapCam 1045 Wearable HD Video Camera Battery, Battery: step 1, image 1 of 1
    • Detach the magnetic clip from the bottom of the camera.
    • The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
  2. iON SnapCam 1045 Wearable HD Video Camera Battery: step 2, image 1 of 1
    • Use a spudger to gently detach the memory card and USB slot cover.
  3. iON SnapCam 1045 Wearable HD Video Camera Battery: step 3, image 1 of 1
    • Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
    • This screw is really tiny and can easily fall off and get lost! Make use of a magnetic mat to hold it in place or better still put the magnetic clip to use for keeping the screw safe.
  4. iON SnapCam 1045 Wearable HD Video Camera Battery: step 4, image 1 of 2 iON SnapCam 1045 Wearable HD Video Camera Battery: step 4, image 2 of 2
    • Once again use the spudger to gently open the encasement.
    • The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
    • The Battery can be safely detached and replaced.
Olakunle
102 Reputation
1 Guide authored
IUPUI, Team S3-G3, Wilson Fall 2017 Member of IUPUI, Team S3-G3, Wilson Fall 2017
IUPUI-WILSON-F17S3G3
3 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 826
