Introduction
Removing the display on a Late 2012 iMac requires cutting through the adhesive around the perimeter of the screen. After the adhesive is cut, it cannot be used to re-seal the display in place, so you'll need to apply a new set of adhesive strips.
Video Overview
If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
Peel off the old strips of adhesive using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
After all the old adhesive is removed, carefully clean the area under the adhesive with 90% (or greater) isopropyl alcohol and a lint-free cloth. Wipe in one direction, not back and forth.
Start with strip 13, which goes on the right vertical side of the rear enclosure.
Peel the short piece of backing off the back of the strip.
Insert the tip of a spudger into the hole at the top of the strip from the side that still has a backing on it.
With the spudger still poking through the hole in the adhesive strip, push the spudger tip into the corresponding hole in the frame of the iMac.
Using the hole and spudger to anchor the position of the adhesive strip, line the strip up against the right edge, gently pull down against the spudger to ensure the strip is taut, and stick it onto the frame.
Once you're satisfied that the top half of the adhesive strip is neatly aligned, peel the longer piece of backing out from behind the strip.
Use your finger to smooth all of strip 13. Make sure it is neatly aligned with the right side of the frame and that it sits flat.
Work your way around the perimeter of the iMac, adding three more adhesive strips in the same manner.
Working counter-clockwise from strip 13, place:
strip 12 on the top right
strip 11 on the top left
strip 16 on the left vertical
On the iMac Intel 27" Retina 5K Display, strip 12's blue tabs will not line up with the top antenna in the same way as the regular model. This is perfectly acceptable and won't impact the performance of the strips or antenna.
Grasp the red film pull tab on the 14 adhesive strip and pull to remove the backing from the strip.
Align the strip on the bottom edge of the rear enclosure, directly to the right of the middle screw on that edge.
Run your finger along the length of the adhesive strip to ensure it is straight and unwrinkled, pressing down as you go to adhere the strip to the iMac.
Repeat the previous step for the 15 adhesive strip, placing it along the left half of the bottom of edge of the iMac.
Use painter's tape or masking tape to temporarily secure the bottom edge of the display to the iMac's enclosure.
If you've already verified that your iMac is working correctly and are ready to seal it up, skip to Step 16.
Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
Flip the display data connector lock down onto the socket.
Insert the display power connector into its socket on the logic board.
After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
Remove the film from the 15 strip by reaching in from above and pulling the tab straight up from the bottom edge of the display.
Steady the display with one hand as you remove the adhesive liners in the following steps, or rest it lightly against the iMac's enclosure.
Repeat the previous steps to remove the protective films from all the remaining adhesive strips (labeled 11, 12, and 13).
Remove the tape securing the display to the rear enclosure.
To ensure a strong bond, carefully tip the iMac flat on its back (with the screen facing straight up) and press carefully but firmly around all four edges of the display.
