Introduction
Rüste deinem RAM auf, damit dein iMac schneller wird.
Löse die einzelne Kreuzschlitzschraube in der Mitte der Zugangsklappe.
Entferne die Zugangsklappe von deinem iMac.
Ziehe die schwarzen Plastiklaschen am RAM mit der Spudgerspitze aus der Öffnung für die RAM heraus.
Ziehe die Lasche vom iMac weg, um das RAM Modul auszuwerfen.
Pulling plastic tabs isn’t releasing the old ram board. How to get this out when black tabs don’t work
Black plastic tabs not releasing the old ram cards. How to get out?
Fasse das RAM Modul an seinen Kanten an und ziehe es gerade aus seinem Einschub heraus.
graphic is not for the proper model iMac. For this series iMac there is only 1 pair (2 total) of memory slots, this graphic displays 2 pairs (4 total). Also there is a lever to eject the ram not plastic tabs.
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
53 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
5 Comments
I believe the EMC2211 model requires PC2-6400 RAM chips instead of the PC2-5300 proposed here.
I don't see any 4 GB RAM chips? I currently have a 2 GB and 4 GB. Was thinking about changing out the 2 GB for a 4 GB. Would it support two 4 GB RAM chips? Do you not sell them?
Ericgossick: according to Apple the most ram you can have is 4 GB. I have heard you can install 2 GB & 4 GB ram chips & the computer will operate normally. If you install 2 (two) 4 GB ram chips the computer will only use 6 GB; it will never use 8 GB. That's just what I've heard. Hope this helps.
Does anyone know if one bank is better than the other for the 4G stick if one is maxxing out their RAM?
PH2 head necessary to remove screw.
airshack - Reply
Mine was as written, a PH1.
tpivo - Reply
