Introduction
Rüste deinem RAM auf, damit dein iMac schneller wird.
Löse die einzelne Kreuzschlitzschraube in der Mitte der Zugangsklappe.
Entferne die Zugangsklappe von deinem iMac.
Ziehe die schwarzen Plastiklaschen am RAM mit der Spudgerspitze aus der Öffnung für die RAM heraus.
Ziehe die Lasche vom iMac weg, um das RAM Modul auszuwerfen.
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
53 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
5 Guide Comments
I believe the EMC2211 model requires PC2-6400 RAM chips instead of the PC2-5300 proposed here.
I don't see any 4 GB RAM chips? I currently have a 2 GB and 4 GB. Was thinking about changing out the 2 GB for a 4 GB. Would it support two 4 GB RAM chips? Do you not sell them?
Ericgossick: according to Apple the most ram you can have is 4 GB. I have heard you can install 2 GB & 4 GB ram chips & the computer will operate normally. If you install 2 (two) 4 GB ram chips the computer will only use 6 GB; it will never use 8 GB. That's just what I've heard. Hope this helps.
Does anyone know if one bank is better than the other for the 4G stick if one is maxxing out their RAM?
