iMac Intel 21.5" EMC 2805 Hard Drive Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 21.5" EMC 2805 Hard Drive Assembly Replacement, Hard Drive Assembly: step 1, image 1 of 3 iMac Intel 21.5" EMC 2805 Hard Drive Assembly Replacement, Hard Drive Assembly: step 1, image 2 of 3 iMac Intel 21.5" EMC 2805 Hard Drive Assembly Replacement, Hard Drive Assembly: step 1, image 3 of 3
    • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
    • The hard drive is attached by a single SATA power/data cableā€”do not attempt to fully remove it from the iMac yet.
  2. iMac Intel 21.5" EMC 2805 Hard Drive Assembly Replacement: step 2, image 1 of 2 iMac Intel 21.5" EMC 2805 Hard Drive Assembly Replacement: step 2, image 2 of 2
    • Use a spudger to disconnect the single SATA power and data combo cable.
  3. iMac Intel 21.5" EMC 2805 Hard Drive Assembly Replacement: step 3, image 1 of 1
    • Remove the hard drive assembly from the iMac.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 162
