You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Prereq only.
Parts
No parts specified.
  1. Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess. The hard drive is attached by a single SATA power/data cable, do not attempt to fully remove it from the iMac. The hard drive is attached by a single SATA power/data cable, do not attempt to fully remove it from the iMac.
    • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
    • The hard drive is attached by a single SATA power/data cable, do not attempt to fully remove it from the iMac.
  2. Use a spudger to disconnect the single SATA power and data combo cable. Use a spudger to disconnect the single SATA power and data combo cable. Use a spudger to disconnect the single SATA power and data combo cable.
    • Use a spudger to disconnect the single SATA power and data combo cable.
  3. Remove the hard drive from the iMac.
    • Remove the hard drive from the iMac.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 65
