Introduction
Prereq for removing logic board.
Push on each side of the left speaker cable connector with the tip of a spudger and gently walk it out of its socket.
De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
Use the flat edge of a spudger to flip up the metal retaining bracket on the iSight camera cable connector.
Pull the iSight camera cable straight out of its socket on the logic board.
Use the flat edge of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
Remove the following screws securing the exhaust duct to the rear enclosure:
Two 6.3 mm T8 screws
Two 4.7 mm T8 screws
Tilt the top of the logic board away from the rear enclosure.
Lift the logic board straight up and out of the iMac.
Use a USB flash drive and/or ethernet cable to ensure the logic board is seated correctly while you screw it in.
