You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Prereq only.
  1. Lift the hard drive from the edge nearest the fan and pull it slightly out of its recess. The hard drive is attached by two cables, do not attempt to fully remove it from the iMac just yet. The hard drive is attached by two cables, do not attempt to fully remove it from the iMac just yet.
    • Lift the hard drive from the edge nearest the fan and pull it slightly out of its recess.
    • The hard drive is attached by two cables, do not attempt to fully remove it from the iMac just yet.
  2. Disconnect the SATA power cable. Disconnect the SATA power cable.
    • Disconnect the SATA power cable.
  3. Unplug the SATA data cable from the hard drive. Unplug the SATA data cable from the hard drive.
    • Unplug the SATA data cable from the hard drive.
  4. Lift and remove the hard drive from the iMac.
    • Lift and remove the hard drive from the iMac.
Sam Goldheart
440,655 Reputation
547 Guides authored
iFixit Member of iFixit
Community
136 Members
16,676 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 96
