Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Parts
No parts specified.
  1. If necessary, remove the pieces of tape securing the hard drive/optical drive thermal sensor cables to your iMac.
    • If necessary, remove the pieces of tape securing the hard drive/optical drive thermal sensor cables to your iMac.
  2. Disconnect the optical drive thermal sensor connector from the logic board by pulling its connector toward the top of your iMac.
    • Disconnect the optical drive thermal sensor connector from the logic board by pulling its connector toward the top of your iMac.
    • When removing this connector, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
  3. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  4. Remove the two fine-thread 7 mm T10 Torx screws securing the optical drive to the rear case.
    • Remove the two fine-thread 7 mm T10 Torx screws securing the optical drive to the rear case.
  5. Lift the free end of the optical drive slightly out of the rear case.
    • Lift the free end of the optical drive slightly out of the rear case.
    • Remove the two 3.5 mm T6 Torx screws securing the optical drive connector to the optical drive.
  6. Insert the flat end of a spudger between the optical drive connector and the body of the optical drive. Twist the spudger to separate the connector from the optical drive.
    • Insert the flat end of a spudger between the optical drive connector and the body of the optical drive.
    • Twist the spudger to separate the connector from the optical drive.
    • It may be necessary to work from alternating sides of the connector until it is disconnected.
  7. Lift the optical drive out of the rear case and pull it away from the side of the rear case to release the strip of EMI tape attached to its surface.
    • Lift the optical drive out of the rear case and pull it away from the side of the rear case to release the strip of EMI tape attached to its surface.
    • The optical drive thermal sensor is still attached to the underside of the optical drive.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 882
