iMac G4 17 800 MHz EMC 1936 RAM Replacement
  1. iMac G4 17 800 MHz EMC 1936 RAM Replacement, Bottom Plate: step 1, image 1 of 1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 RAM Replacement: step 2, image 1 of 1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 RAM Replacement: step 3, image 1 of 1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 RAM Replacement, RAM: step 4, image 1 of 2 iMac G4 17 800 MHz EMC 1936 RAM Replacement, RAM: step 4, image 2 of 2
    • Remove the RAM from the slot.
14 other people completed this guide.
David Hunter
650 Reputation
4 Guides authored
Cal Poly, Team 21-22, Maness Fall 2011 Member of Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 Members
13 Guides authored
One Comment
We need to show the RAM being taken off
David Hunter - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 5,161
