Introduction
Replace the optical drive in your iMac G4 15".
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
Using a Torx #9 screw driver, remove the two 8.77mm screws holding the drive's shield onto your iMac G4.
Remove the drive shield from your iMac.
Using a Torx # 10 screw driver, remove the four 19.12mm screws that mount the optical drive.
Grasp the HD/Optical Drive bundle by the by the sides and gently wiggle it loose from the sides.
Unplug the power source from the optical drive by pinching the plastic base of the connector and wiggling it gently.
Unplug the ribbon cable from the optical drive by grasping the plastic base of the connector and wiggling it gently.
