Introduction
This is an internal prerequisite guide that should remain unpublished.
Remove the pieces of readily removable tape from around the perimeter of the display.
Carefully remove the aluminum tape covering the display data cable connection.
Remove the single screw inserted through the piece of EMI tape near the bottom edge of the display.
Use the tip of a spudger to remove the small washer under the screw you just removed.
Remove the two Phillips screws securing each side of the LCD to the clutch hinge frame (four screws total).
