Introduction
The metallic bottom shield protects the logic board from electromagnetic interference.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case.
Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
Once the front and sides of the lower case are free, turn the computer so that the back is facing you.
Pull the lower case up and toward you until the back tabs pop free.
Remove the small greasy springs with white plastic caps from either side of the battery contacts.
Remove the following 10 screws:
One 5 mm Phillips at the upper, right corner of the battery compartment.
Nine 6 mm Phillips scattered around the shield.
Lift the bottom shield off.
