HP 250 G3 WiFi Card Replacement
  1. HP 250 G3 WiFi Card Replacement, WiFi Card: step 1, image 1 of 1
    • Remove the battery.
  2. HP 250 G3 WiFi Card Replacement: step 2, image 1 of 1
    • Remove the two indicated screws using a #1 Phillips driver.
  3. HP 250 G3 WiFi Card Replacement: step 3, image 1 of 3 HP 250 G3 WiFi Card Replacement: step 3, image 2 of 3 HP 250 G3 WiFi Card Replacement: step 3, image 3 of 3
    • Use a #1 Philips driver to remove the disc drive's screw.
    • Using a spudger, gently pry the drive out of the housing.
  4. HP 250 G3 WiFi Card Replacement, screws of the case 1: step 4, image 1 of 3 HP 250 G3 WiFi Card Replacement, screws of the case 1: step 4, image 2 of 3 HP 250 G3 WiFi Card Replacement, screws of the case 1: step 4, image 3 of 3
    • Remove the rubber rests on the rear of the device, which are close to the battery.
    • Remove the hidden screws placed under the rests using a #1 Philips driver.
  5. HP 250 G3 WiFi Card Replacement, screws of the case 2: step 5, image 1 of 3 HP 250 G3 WiFi Card Replacement, screws of the case 2: step 5, image 2 of 3 HP 250 G3 WiFi Card Replacement, screws of the case 2: step 5, image 3 of 3
    • Remove the remaining screws on the bottom of the device.
    • Remove the two little screws at the DVD entrance.
  6. HP 250 G3 WiFi Card Replacement, removing keyboard: step 7, image 1 of 3 HP 250 G3 WiFi Card Replacement, removing keyboard: step 7, image 2 of 3 HP 250 G3 WiFi Card Replacement, removing keyboard: step 7, image 3 of 3
    • Turn the laptop around.
    • Open up the laptop (to remove the keyboard).
    • Use a spudger or iSesamo to remove the keyboard.
    • Slide the iSesamo around the upper side of the keyboard as shown in the pictures (you will hear clicks).
  7. HP 250 G3 WiFi Card Replacement: step 8, image 1 of 3 HP 250 G3 WiFi Card Replacement: step 8, image 2 of 3 HP 250 G3 WiFi Card Replacement: step 8, image 3 of 3
    • When it becomes loose, gently slide the keyboard to the left as shown in the third picture.
    • Be gentle as the thin ribbon can easily tear.
  8. HP 250 G3 WiFi Card Replacement, removing keyboard / ribbon cable: step 9, image 1 of 3 HP 250 G3 WiFi Card Replacement, removing keyboard / ribbon cable: step 9, image 2 of 3 HP 250 G3 WiFi Card Replacement, removing keyboard / ribbon cable: step 9, image 3 of 3
    • Gently lift the keyboard up.
    • Spot the thin ribbon cable attached to the connector (the connector has a plastic lid).
    • Carefully open the lid with a spudger and slide the ribbon cable out of the connector.
    • Be very gently with the cable and the connector as the lid may come loose.
    • Close the lid after removing the cable so that the cable cannot fall out.
  9. HP 250 G3 WiFi Card Replacement, removing upper plate/case: step 10, image 1 of 3 HP 250 G3 WiFi Card Replacement, removing upper plate/case: step 10, image 2 of 3 HP 250 G3 WiFi Card Replacement, removing upper plate/case: step 10, image 3 of 3
    • Remove the screw circled in the second picture.
    • Remove the tape over the cable and the connector.
    • Remove the white ribbon cable from the connector.
    • Open up the lid with a spudger, and gently remove the ribbon cable.
    • Use caution, as the ribbon cable is pasted to the plate.
    • This ribbon cable is the connector from the ON/OFF switch.
  10. HP 250 G3 WiFi Card Replacement: step 11, image 1 of 2 HP 250 G3 WiFi Card Replacement: step 11, image 2 of 2
    • Remove the circled screw.
    • Remove the ribbon cable from the connector.
    • The ribbon cable/connector is the touch pad/mouse connector.
  11. HP 250 G3 WiFi Card Replacement: step 12, image 1 of 1
    • Remove the screw on the upper side of the laptop.
    • Remove the last screw (unfortunately, I do not have a picture of this, but you will see it on your laptop).
  12. HP 250 G3 WiFi Card Replacement: step 14, image 1 of 3 HP 250 G3 WiFi Card Replacement: step 14, image 2 of 3 HP 250 G3 WiFi Card Replacement: step 14, image 3 of 3
    • Slide your iSesamo around the case as shown in picture 1 and 2, and go around the entire laptop.
    • You will hear clicks after using the iSesamo.
    • Lift the upper plate to reveal the motherboard.
  13. HP 250 G3 WiFi Card Replacement, removing main board: step 15, image 1 of 3 HP 250 G3 WiFi Card Replacement, removing main board: step 15, image 2 of 3 HP 250 G3 WiFi Card Replacement, removing main board: step 15, image 3 of 3
    • Remove the two screws holding the main board to the plate (see pictures two and three).
  14. HP 250 G3 WiFi Card Replacement, loose screws and cables to remove main board: step 16, image 1 of 1
    • Use an IC extractor to remove the audio connector from the socket.
  15. HP 250 G3 WiFi Card Replacement, removing LCD cable: step 17, image 1 of 3 HP 250 G3 WiFi Card Replacement, removing LCD cable: step 17, image 2 of 3 HP 250 G3 WiFi Card Replacement, removing LCD cable: step 17, image 3 of 3
    • Use a spudger to remove the tape/sticker.
    • Be very gentle as the connector is a hard-to-remove ribbon cable with several small cables. Ripping one of them will damage the ribbon cable, and will thereby damage the screen.
    • It is recommended to use an IC extractor to remove the LCD connector (however, you can use two small flathead screwdrivers or tweezers to slide the connector out of the socket).
  16. HP 250 G3 WiFi Card Replacement, removing HDD: step 18, image 1 of 2 HP 250 G3 WiFi Card Replacement, removing HDD: step 18, image 2 of 2
    • Remove the two screws holding the HDD.
    • Slide out the HDD.
  17. HP 250 G3 WiFi Card Replacement, removing usb pcb: step 19, image 1 of 3 HP 250 G3 WiFi Card Replacement, removing usb pcb: step 19, image 2 of 3 HP 250 G3 WiFi Card Replacement, removing usb pcb: step 19, image 3 of 3
    • Use a spudger to loosen the cable from the bottom plate.
    • The flat ribbon cable is pasted to the bottom plate, and the ribbon cable is soldered to the PCB.
  18. HP 250 G3 WiFi Card Replacement, removing the bad Wifi module.: step 20, image 1 of 3 HP 250 G3 WiFi Card Replacement, removing the bad Wifi module.: step 20, image 2 of 3 HP 250 G3 WiFi Card Replacement, removing the bad Wifi module.: step 20, image 3 of 3
    • Remove the golden antenna cable from the socket. Be very careful, and use a spudger.
    • Remove the screw.
    • The WiFi module will jump up when the screw is removed. Slide the WiFi module out.
    • Wear gloves to avoid touching the antenna or the antenna sockets.
    • To install the new Wifi module, slide the new WiFi module in, push it down, and drive the screw back in.
    • Reattach the antenna.
  19. HP 250 G3 WiFi Card Replacement, removing main PVB: step 21, image 1 of 3 HP 250 G3 WiFi Card Replacement, removing main PVB: step 21, image 2 of 3 HP 250 G3 WiFi Card Replacement, removing main PVB: step 21, image 3 of 3
    • In this case I did not remove the main PCB because I would have had to remove the DC jack. It is a very breakable connector, and the wires are very thin. If they are broken the laptop will no longer charge.
    • If the DC jack is damaged or broken in your laptop, remove the hinge instead (this is holding the DC power jack in place).
10 other people completed this guide.
Kevin D
7,294 Reputation
21 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 66
All Time: 11,418
