Changes to Step #4
Edit by Miroslav Djuric
Edit approved
Deleted
Added
Unchanged
Step #4 Lines
[* black] The left display hinge comes out with no issues, but good luck separating it from the display data cable.
[* black] Devices with [guide|6175|cables fed through hinges|stepid=26752] can be a real bear to work on. None of that will be an issue with this machine, though, as the display hinge is pretty much sealed shut at the factory. Rather than having to feed cables throughrouting the hinge,cable under a [http://guide-images.ifixit.net/igi/JspHSGFcAVh24LUd.huge|cable retainer] -- as it's done in non-Retina MacBook Pros -- you just have to replace themboth cable and hinge together.
[* black] Don't think that the guys (and gals) who designed this machine are just out to get you. Routing the cables through the hinge is an easya way to save space and weight in the display assemblylaptop.
