Changes to Step #4
Edit by David Hodson
Edit approved
Deleted
Added
Unchanged
Step Lines
[* black] The left display hinge comes out with no issues, but good luck separating it from the display data cable.
[* black] Devices with [guide|6175|cables fed through hinges|stepid=26752] can be a real bear to work on. None of that will be an issue with this machine, though, as the display hinge is pretty much sealed shut at the factory. Rather than having to feed cables through the hinge, you just have to replace them together.
[* black] Don't think that the guys (and gals) who designed this machine are just out to get you. Feeding cables through the hinge is an easy way to save space in what is already a cramped spacethe display assembly..
