Changes to Step #10
Edit by Walter Galan
Edit approved
Deleted
Added
Unchanged
Step Lines
[* black] RemoveUse a spudger to disconnect the inverter cablecable from the corner of the left I/O board.
[* black] Support the display with one hand while removing the following 3 screws:
[* red] Two 9.5 mm silver T6 Torx screws with threads on only part of the shaft on the inside of the display hinges.
[* orange] One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
[* black] Grasp the display assembly on both sides and lift it up and out of the computer.
