Changes to Step #0
Edit by Miroslav Djuric
Edit approved
Deleted
Added
Unchanged
Step #0 Lines
[* icon_caution] Use caution when removing the thermal sensor connector. The connector can easily break off the logic board if this step is performed improperly.
[* black] Disconnect the right thermal sensor cable from the logic board by placing a spudger beneath the cable and lifting up.
[* standard] Peel up the orange Kapton tape covering the right thermal sensor.
[* standard] Use a spudger to pry the right thermal sensor off the lower case.
