Changes to Step #17
Edit by Anton Smith
Pending approval
Deleted
Added
Unchanged
Step Lines
[* black] Mac Mini Mid 2011 Repairability: '''8 out of 10''' (10 is easiest to repair).
[* green] No proprietary screws are found within the device.
[* green] You can easily upgrade your RAM and hard drive, as well as add a secondary drive.
[* green] There's no glue anywhere inside that needs to be removed while disassembling the Mini.
[* red] The CPU (as well as the GPU in the $800 model) is soldered to the logic board and not user-upgradeable.
[* red] While not difficult to do, you still have to remove almost all the internals in order to replace the power supply.
