Changes to Step #0
Edit by Luke Soules
Edit approved
Deleted
Added
Unchanged
Step #0 Lines
[* standard] Internals view with the upper case removed. Notable features:
[* standard] 120 GB longitudinal recording Fujitsu drive. Rumor has it the 160 GB model ships with a perpendicular drive.
[* standard] The optical drive is now a 6X, dual-layer, 9.7mm SuperDrive (DVD-R DL/DVD-RW/CD-RW). The drive itself says UJ-857C, while System Profiler reports it as a UJ-857D. We can't explain the discrepancy.
[* icon_note] The logic board layout is virtually identical to the previous model. Apple introduced a new cable connector that is soldered to the logic board better thisbetter. This may reduce some of the problems we've had with the previous brittle connectors.
