Changes to Step #13
Edit by Brett Hartt
Edit approved
Deleted
Added
Unchanged
Step #13 Lines
[* black] Parrot AR.Drone Repairability: '''8 out of 10''' (10 is easiest to repair).
[* green] The battery and upper case come off easily without removing a single screw.
[* green] Almost everything is attached via ribbon cable connectors and screws, making replacement much more feasible.
[* green] Parrot provides replacement parts and repair videos for common problems.
[* yellow] The circlipsc-clips on each propeller assembly are very hard to remove without the correct tool.
[* yellow] It's a pain to reapply adhesive after removing all the adhered parts.
