Changes to Step #4
Edit by Mark Warren
Pending approval
Step Lines
[* black] Next, we turn to the underside of the quadricopter.
[* black] After removing four T6 Torx screws, the lower plate can be lifted off to reveal the motherboard and navigation board.
[* black] The navigation board is connected to the motherboard by eight pins and comes out without any hassle.
[* black] Note: The ribbon cable (from the front camera) is inserted into the navigation board with a ZIF like connector, gently pull the black portion of the connector away from the white portion and it will make removing the ribbon cable far easier.If the ribbon cable feels tight, you probably have not 'unlocked' the connector. Be careful! If you pull too hard you risk damaging or severing the ribbon cable, and you'll need to purchase a body and camera replacement.
