Changes to Step #3
Edit by David Hodson
Edit approved
Deleted
Added
Unchanged
Step #3 Lines
[* black] The 1000mAh 11.1V Lithiumlithium polymer battery is attached via a connector, making it delightfully easy to remove.
[* black] The second connector on the battery is not connected to anything inside the AR.Drone, but is used to charge the battery.
[* black] Parrott claims the battery will last 15 minutes after a full charge, which takes around 90 minutes.
