Changes to Step #7
Edit by Walter Galan
Edit approved by Walter Galan
Deleted
Added
Unchanged
Step Lines
[* black] Checkpoint reached—battery released!
[* black] Though the 5c is essentially a repackaged iPhone 5 (in colored plastic, in case that hadn't been made apparent, yet), the battery ''has'' been beefed up a bit, clocking in at 3.8V—5.73Wh—1510mAh3.8 V—5.73 Wh—1510 mAh, compared to the 3.8V—5.45Wh—1440mAh3.8 V—5.45 Wh—1440 mAh battery of the iPhone 5.
[* icon_note] Hopefully, this will address [http://www.extremetech.com/computing/166884-iphone-5-battery-life-is-significantly-reduced-by-ios-7|some issues] with battery life brought about by the iOS 7 update.
[* black] Larger battery…Hmmm, could the "c" stand for battery "capacity?" It's a theory—it's probably wrong.
