Changes to Step #0
Edit by Andrew Bookholt
Edit approved
Deleted
Added
Unchanged
Step #0 Lines
[* black] Insert wisdom hereBe sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
[* red] Remove the last remaining 6 mm T6 Torx screw securing the display to the upper case
Image 1
Old Version
New Version
