Changes to Step #0
Edit by Andrew Bookholt
Edit approved
Deleted
Added
Unchanged
Step #0 Lines
[* black] Insert wisdom hereGrab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
[* black] Rotate the display slightly away from the upper case.
[* black] Lift the display up and away from the upper case, minding any brackets or cables that may get caught
