Changes to Step #4
Edit by Andrew Bookholt
Edit approved
Deleted
Added
Unchanged
Step Lines
[* icon_note] This step is only required if you have an anti-glare display. If you have a glossy display, skip to step 12.
[* black] Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
[* icon_caution] Pull the connector parallel to the face of the logic board, not straight up.
[* black] Use the flat end of a spudger to pry the Bluetooth antenna cable up from its socket on the board.
Image 1
No previous image
Added
Image 2
No previous image
Added
