Changes to Step #12
Edit by Miroslav Djuric
Edit approved by Miroslav Djuric
Deleted
Added
Unchanged
Step #12 Lines
[* black] Nexus 7 2nd Generation Repairability Score: '''6 out of 10''' (10 is easiest to repair)
[* green] The rear case is very easy to open, and requires minimal prying effort with a plastic opening tool to removeremove... But we cracked it, even though we were quite careful during the opening procedure.
[* green] All fasteners inside are Phillips screws—no security or proprietary screws here.
[* yellow] While the battery enclosure is easy to remove, some patient spudgering will be necessary to peel the battery off the tray.
[* red] The front glass is adhered to the display frame, meaning you'll need a heat gun to get the LCD out.
