Changes to Step #12
Edit by Andrew Optimus Goldberg
Edit approved by Andrew Optimus Goldberg
Deleted
Added
Unchanged
Step #12 Lines
[* black] Nexus 7 2nd Generation Repairability Score: '''6 out of 10''' (10 is easiest to repair)
[* green] The rear case is very easy to open, and requires minimal prying effort with a plastic opening tool to remove.
[* green] All fasteners inside are Phillips #00 screws—no security or proprietary screws here.
[* yellow] While the battery enclosure is easy to remove, some patient spudgering will be necessary to peel the battery off the tray.
[* red] The front glass is adhered to the display frame, meaning you'll need a heat gun to get the
