Changes to Step #6
Edit by Andrew Bookholt
Edit approved
Step Lines
[* black] Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
[* black] Rotate your spudger toward the rear bezel to separate it from the front bezel.
[* black] If necessary, continue separating the left edge of the rear bezel off the tabs on the front display bezel.
