Changes to Step #0
Edit by Walter Galan
Edit approved
Deleted
Added
Unchanged
Step #0 Lines
[* standard] Insert wisdom herethe flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
[* black] Rotate your spudger toward the rear bezel to separate it from the front bezel
