Changes to Step #21
Edit by Walter Galan
Edit approved by Walter Galan
Deleted
Added
Unchanged
Step Lines
[* black] MacBook Pro 13" Retina Display Repairability: '''2 out of 10''' (10 is easiest to repair)
[* yellow] There appears to be enough space to fit a regular 5 mm or 7 mm 2.5" laptop drive, but a custom cable will need to be developed.
[* red] The battery is still glued into the laptop's top case, but it's slightly less difficult to remove compared to the [guide|9462|15" model].
[* red] Proprietary pentalobe screws prevent you from gaining access to anything inside.
[* red] The RAM is surface-mount soldered to the logic board, so no upgrade is possible. It will forever have 8 GB of RAM.
[* red] The display assembly is almost impossible to take apart. If anything ever fails inside the display, you'll need to replace the display as a whole.
