Changes to Step #16
Edit by Andrew Optimus Goldberg
Edit approved by Andrew Optimus Goldberg
Deleted
Added
Unchanged
Step #16 Lines
[* black] iPod Nano 7th Generation Repairability: '''5 out of 10''' (10 is easiest to repair).
[* green] An easy-to-open case only requires unscrewing two screws and a plastic opening tool.
[* green] The bluetooth antenna is replaceableLCD and digitizer glass are not fused together, allowing replacement of either component separately.
[* green] Only standard Phillips #00 screws are used—no security or pentalobe.
[* yellow] External screws hidden behind the antenna mean less adhesive holding down the display assembly.
[* red] The battery, Lightning connector, button cable, and headphone jack are all soldered to the logic board.
[* red] The battery is adhered to the back of the display assembly.
