Changes to Step #16
Edit by Andrew Optimus Goldberg
Edit approved by Andrew Optimus Goldberg
Deleted
Added
Unchanged
Step Lines
[* black] iPod Nano 7th Generation Repairability: '''4 out of 10''' (10 is easiest to repair).
[* green] Easy to open case requires only unscrewing two screws and a plastic opening tool.
[* green] Replaceable Bluetooth antenna.
[* green] Only standard Phillips #00 screws, no security or pentalobe.
[* yellow] External screws hidden behind the antenna mean less adhesive holding down the display assembly.
[* red] The battery, Lightning connector, button cable, and headphone jack are all soldered to the logic board.
[* red] Battery is adhered to the back of the display assembly.
[* red] Digitizer cable is difficult to disconnect and gets in the way of removing the display assembly.
